[mapserver-users] Image handling error
Christian Willmes c.willmes at uni-koeln.de
Tue Sep 2 06:42:49 EDT 2008
Hello,
I'm trying to set up a WMS using Mapserver.
On my local System I get it to work using vector data (shapefiles) and
raster data input.
On the public webserver from our universities computing centre, I don't
get it to work with 'quite' similar setup as on my local test system
(problem is, I don't get admin rights to configure it my self on the
server, so I have to ask the admins for every installation etc).
Just using vector data it works fine, but by using raster data input I
get the following message:
msDrawMap(): Image handling error. Failed to draw layer named
'srtm_elevation'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image
format
drawEPP(): Image handling error. EPPL7 support is not available.
I asked the admins to check the gdal installation on the server. It
seems all is installed properly. The raster format I'm using is
supported according to the gdalinfo output the admins provided me:
a0646 at lvr18$ gdalinfo --formats
Supported Formats:
 GTiff (rw+): GeoTIFF
 PNG (rw): Portable Network Graphics
 JPEG (rw): JPEG JFIF
 BMP (rw+): MS Windows Device Independent Bitmap
I converted the data to the four above mentioned formats (wich are
supported by the servers GDAL installation according to gdalinfo). But
its all the same error on the server. These data are all works fine on
my local setup with mapserver.
There was a similar Thread a month ago
(http://lists.osgeo.org/pipermail/mapserver-users/2008-August/057027.html)
on this list. But
as far as I can see no resolution for the problem? Is this problem
solved meanwhile?
Thanks very much in advance!
Best regards,
Christian
Christian Willmes
AG GIS & Fernerkundung		| GIS & RS Group
Geographisches Institut		| Institute of Geography
Universität Köln		| University of Cologne
http://www.geographie.uni-koeln.de/gis/
Tel.: +49 (0)221 470 7431
