[mapserver-users] howto draw amount of points features of one
layer depending on scale
Nils Zierath
nils.zierath at uni-bonn.de
Tue Sep 2 07:13:34 EDT 2008
Yewondwossen,
thanks for the link. I had to switch off the "FORCE true" option of the sample map file
and it now works perfectly.
Nils
Yewondwossen Assefa schrieb:
> Nils,
> look at this thread: it gives details of what you want to accomplish
> with an example of a working layer:
> http://www.mail-archive.com/mapserver-users@lists.osgeo.org/msg00164.html
> Best Regards,
> Nils Zierath wrote:
>> Hi David,
>> your suggestion is similar to Jeff's?
>> How would I treat a point as lable? I haven't had any luck in
>> displaying the points with "TYPE ANNOTATION".
>> What would the syntax in the mapfile would look like to either treat a
>> point as lable or with "TYPE ANNOTATION"?
>> My mapfile currently looks like:
>> LAYER
>> NAME 'Field research locations'
>> DATA '../vector/gps/fieldresearch_complete'
>> STATUS default
>> TYPE point
>> #TYPE annotation
>> TRANSPARENCY 100
>> TOLERANCE 7
>> TOLERANCEUNITS pixels
>> UNITS kilometers
>> METADATA
>> END #METADATA
>> PROJECTION
>> END #PROJECTION
>> CLASSITEM 'StudyFocus'
>> #LABELITEM 'LableAnnot'
>> CLASS
>> NAME 'Research locations (all)'
>> #MINSCALEDENOM 1000000
>> STYLE
>> SYMBOL 'ttf_pin-sm'
>> SIZE 10
>> COLOR 255 180 0
>> ANGLE 345
>> END #STYLE
>> END #CLASS
>> END #LAYER
>> David Percy schrieb:
>>> If you treated them as labels when zoomed out (maxscale 50000 for
>>> example), then you could take advantage of the label colission
>>> features of mapserver to avoid overlaps.
>>> when zoomed in further you could have another layer (minscale 50000
>>> for example) that shows all the detail...
>>> so you would have two layer definitions in this case...
>>> Cheers,
>>> Percy
>>> Nils Zierath wrote:
>>>> Dear list,
>>>> I got a layer with gps points. On the largest scale of my map the
>>>> symbols for points overlap and are not distinguishable from one
>>>> another since they are too close together.
>>>> Is it possible to tell mapserver to draw only that many of the
>>>> points/symbols that do not overlap, so that more points will be
>>>> shown the more I zoom into the map?
>>>> Thank you,
>>>> Nils
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
