[mapserver-users] Highlighting query results
Steve Lime Steve.Lime at dnr.state.mn.us
Tue Sep 2 14:11:33 EDT 2008
MapServer supports what's called a query map. It basically replaces the color of the top-most
style for a layer with one defined in the query map object (default is yellow). Typically in MapScript
you'd do:
  a_layer.queryByAttributes(m_map, null, a_query, 1);
  img = m_map.drawQuery();
You can of course get fancier and step through the result set by hand but I wouldn't recommend
starting that way.
Steve
>>> On 9/2/2008 at 9:14 AM, in message
<E1KaWeU-0008jG-00.shurhenv-mail-ru at f10.mail.ru>, shurhen <shurhenv at mail.ru>
wrote:
> Hi!
> I'm newbie in mapserver :)
> I need to highlight query results. I wanna select object by attribute and
> then highlight it. But I've not found any information how can I do this. Most
> of GIS have possibility to highlight selected objects, therefore I suppose
> what MapServer has this ability too. "Selected" means to highlight object
> when I click at it, and to return to its previous color when I click at
> another object.
> I've found similar question
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0309/msg00063.html
> but unfortunately it remains without any answer :(
> If there is no way except to color selected object manually, please help me
> to do this too.
> Here is Mapscript code example based on the info what I found on this site:
>             using (resultCacheObj results = a_layer.getResults())
>                 if (results != null && results.numresults > 0)
>                     a_layer.open();
>                     for(int i = 0; i < results.numresults; i++)
>                         resultCacheMemberObj a_result =
> results.getResult(i);
>                         shapeObj a_obj =
> a_layer.getFeature(a_result.shapeindex, a_result.tileindex);
>                         //           WHAT NEXT??
>                     a_layer.close();
> PS Sorry for my English, but I hope you've understood me
> mapserver-users at lists.osgeo.org
