[MAPSERVER-USERS] Highlighting query results
Ящик на mail.ru
shurhenv at mail.ru
Thu Sep 4 07:14:07 EDT 2008
Yes!
After query has been performed I have a_layer.getResults() > 0
and
imageObj img = m_map.drawQuery(); // here img is not null
I've saved img into file and noticed that selection is exists!
img.save("query1234.gif", m_map); // Here selected object has been
highlighted!
So I finally have decided that problem is in the map refreshing :)
I've looked in this method and found in what there was a problem:
before output image to the PictureBox component (via MemoryStream)
there was such line:
image = m_map.draw(); // this code annihilated m_map.drawQuery()
Therefore I've changed it on
image = m_map.drawQuery();
and all have been done!
This work and if there no query at all. there are exceptions not rise
and map drawing correctly.
Steve Lime, thanks for your answers!
PS
I wanna post my message in same branch, but instead my message appears in
the root. How can I do that?
>Are you sure the search is returning something? (e.g. it worked)
>Steve
>>>> On 9/3/2008 at 7:54 AM, in message
><E1Karsf-0003Qy-00.shurhenv-mail-ru at f114.mail.ru>, shurhen <shurhenv at mail.ru>
>wrote:
>> Thank you, Steve!
>>> I tried your way, but I have not got result - selected object still remains
>> same as others.
>> I've added these lines in map-file but there are no results:
>> QUERYMAP
>> COLOR 0 0 255
>> STATUS ON
>> STYLE HILITE
>> END
>> What I've missed?
