Fwd: [mapserver-users] ArcSDE 9.2 support
Oscar Gomez ogomez2 at gmail.com
Thu Sep 4 11:24:55 EDT 2008
 My 2 cents: ArcSDE 9.2 stores by default in Unicode.
I'm afraid you'll need to reload all the data again to ArcSDE, using a
keyword that does not store the string data in unicode by default.
Workaround:
a) Create a new ArcSDE keyword (or modify a existing one) with sdedbtune -o
export (and after -o import), to include the following entry:
UNICODE_STRING             "FALSE"
b) Load the data using an ArcSDE Oracle Spatial (SDO) keyword, then use
MapServer with Oracle Spatial, removing the "ANNO_CAD_DATA" with the query
in the map file.
Best,
Oscar
*Oscar GOMEZ PRIETO*
*Joint Research Centre
European Commmission                                  *
*Institute for Environment and Sustainability
Rural, Water and Ecosystem Resources Unit                       *
*Building 26A Office nº132 TP 262
Via Enrico Fermi 2749
I-21027, ISPRA(VA) Italy
Tel. **+39 - 03.32.78.38.24
E-mail: **oscar.gomez at jrc.it* <oscar.gomez at jrc.it>*
Unit Web site: **http://agrienv.jrc.it/** ***
*DISCLAIMER:** The views expressed are purely those of the writer and may
not in any circumstances
be regarded as stating an official position of the European Commission.*
*P** ** **Please consider the environment before printing this e-mail***
  On Thu, Sep 4, 2008 at 4:16 PM, Joshua Hevenor <jhevenor at rogers.com>wrote:
>    Are your labels coming out garbled or not drawing at all. There's some
> incompatability between using NVARCHAR and VARCHAR as your source data. If
> your labels are showing up but are unreadable this could be the problem. Let
> me know, and when I get back to my office I can provide you with more
> detail.
> Cheers,
> Josh Hevenor
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080904/4d0fa1e8/attachment.html
