[mapserver-users] High CPU
Jeff McKenna
jmckenna at gatewaygeomatics.com
Fri Sep 5 18:27:03 EDT 2008
my quick thoughts:
- make sure you are using MS4W 2.2.9 (latest)
- make sure your shp has a qix file with it (created by shptree.exe)
- test draw speed with shp2img.exe command with -map_debug 5
- make sure no projections-on-the-fly are occurring
....start with that anyway...
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
Steve White wrote:
> I’m running the latest version of MS4W on a virtual private server with
> the following:
> - 2003 Server
> - IIS 6.0
> - Intel Xeon CPU 3.20Ghz
> - 640MB RAM
> I have one shapefile 850KB and a basic mapfile like below:
> MAP
> NAME Test
> STATUS ON
> UNITS METERS
> SHAPEPATH "C:\Inetpub\scripts\data\"
> IMAGECOLOR 0 255 255
> SIZE 400 400
> DEBUG ON
> IMAGETYPE PNG
> EXTENT -4.35 56.14 -3.23
> 56.91
> WEB
> METADATA
> "wms_title" "Test MS"
> "wms_onlineresource"
> "http://localhost/scripts/mapserv.exe&"
> "wms_srs" "EPSG:4326 EPSG:54004
> EPSG:27700"
> "wms_feature_info_mime_type" "text/html"
> END
> IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
> IMAGEURL "C:\Inetpub\wwwroot\tmp\"
> LOG
> "C:\Inetpub\wwwroot\tmp\mapserver.log"
> TEMPLATE
> "C:\Inetpub\wwwroot\Test\templates\template.html"
> EMPTY
> "C:\Inetpub\wwwroot\Test\templates\template_empty.html"
> END
> PROJECTION
> "init=epsg:4326"
> END
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> LAYER
> NAME Test
> METADATA
> "wms_title" "Test"
> "gml_include_items" "all"
> "wms_include_items" "all"
> END
> TYPE POINT
> DATA
> Test
> STATUS ON
> DUMP TRUE
> CLASS
> TEMPLATE
> "C:\Inetpub\wwwroot\Test\templates\template_test.html"
> STYLE
> SYMBOL "circle"
> SIZE 10
> COLOR 0 0 255
> END
> END
> END #end of layer
> END # end of mapfile
> I’m sending WMS GetMap requests to the layer from my localhost and
> monitoring CPU on the server.
> Every time I send a request the server CPU hits 100% until the request ends.
> 1) Is 640MB RAM enough to cope with this simple request?
> 2) Is there anything wrong with the mapfile?
> 3) Are there any methods I can use to tune this further?
> Cheers,
> Steve
