[mapserver-users] High CPU
Ed McNierney ed at mcnierney.com
Sun Sep 7 17:20:21 EDT 2008
Steve -
Your CPU spends 100% of its time doing SOMETHING.  You seem to be focusing on high CPU utilization by a process as being a bad thing, and in many case it is instead a very good thing.  Many MapServer applications are I/O bound, waiting for disk seeks, etc.  Since your CPU is not waiting for I/O to any significant degree, 100% CPU utilization means you're not suffering from that I/O limitation.
If your machine is not doing anything else, seeing 100% CPU utilization is good.  If you are testing with 10 other applications in active use, having one of them consume 100% of the CPU is bad.  But I think you may need to do more sophisticated load testing in order to evaluate your situation; adding more RAM is most likely to be helpful in a multi-user, heavily-loaded situation.  It might not help much, however, and you can only tell by doing multi-user (and in your case, multi-application) simulated load tests.
    - Ed
Ed McNierney
205 Indian Hill Road
Groton, MA  01450
ed at mcnierney.com
+1 (978) 761-0049
On 9/7/08 4:32 PM, "Steve White" <steve at online-archaeology.co.uk> wrote:
Ed -
The reason I feel edgy is because I have other hosted .NET applications on the same box.
I discovered from my tests that another process (CSRSS.exe) is also using excessive CPU (about 40%), so it's not all MapServer, so I'm going to set up some auto tests scripts to find out what kind of a ceiling I have and see if I can pull down CSRSS.exe a bit.
Cheers,
Steve
Sent: 07 September 2008 13:48
To: Steve White; Paul Ramsey
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] High CPU
Steve -
Would you prefer your CPU was sitting idle?  Keeping the CPU busy is a good thing, isn't it?  It means your network, disk, and other resources are not preventing your CPU from working at full capacity.
What makes you feel that running your CPU at 100% capacity is a bad thing?
    - Ed
Ed McNierney
Groton, MA  01450
ed at mcnierney.com
+1 (978) 761-0049
On 9/7/08 4:20 AM, "Steve White" <steve at online-archaeology.co.uk> wrote:
The problem is that CPU shoots to 100% while tiles are being generated from
a remote WMS call.
The shp2img dump was taken directly on the server but the problem occurs
when I send remote WMS requests to the server.
I'm starting to think that 640MB RAM isn't enough and I should probably bump
it up to 1GB.
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
Sent: 07 September 2008 06:07
To: Steve White
It took 0.3s to run to completion, what's the problem precisely?
P.
On Sat, Sep 6, 2008 at 1:35 PM, Steve White
> Thanks Jeff -
> -          I upgraded to MS4w 2.2.9
> -          I ran shptree.exe and produced the index file
> -          My results of shp2img.exe are below
> -          I don't think any projections-on-the-fly are occurring
> Shp2img dump:
> msDrawMap(): Layer 0 (OA), 0.015s
> msDrawMap(): Drawing Label Cache, 0.000s
> msDrawMap() total time: 0.015s
> SaveImage() total time: 0.297s
> msFreeMap(): freeing map at 0144B498.
> I'm still getting very high CPU usage with just one active session, so
> there's no way I can go into production till this is resolved.
> Any other things I can look at?
> Cheers,
> Steve
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080907/b01d997d/attachment.html
