[mapserver-users] drawing a circle
Steve Lime
Steve.Lime at dnr.state.mn.us
Mon Sep 8 14:33:47 EDT 2008
Create a layer in your mapfile like so:
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS 1 1 END
END
LAYER
NAME 'myPoiint'
TYPE POINT
STATUS OFF
CLASS
STYLE
COLOR 255 0 0
SIZE 15
END
END
END
Then in your script, the steps would be like so:
1) get the 'myPoint' layer
2) add a point feature to it
3) set the STATUS appropriately
Now draw as normal. Assuming the point is in map coordinates you should see a red circle at the location
you specified.
Steve
>>> On 9/8/2008 at 11:15 AM, in message
<3702658f0809080915y38b42472le294cbda8e40b45e at mail.gmail.com>, "ramya
srinivasan" <hellomps at gmail.com> wrote:
> Hi,
> iam using php/mapscript.I will have to display the point clicked by the user
> on the map. This is my task.Can u pls help me
> On Mon, Sep 8, 2008 at 9:18 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
>> Can you explain a bit more about your environment (CGI vs. MapScript),
>> context of the need etc...?
>> The easiest path will likely involve a point layer that you'll populate
>> dynamically (with the click coordinate) and then display that point with a
>> circle symbol. You can scale that symbol appropriately using a style SIZE
>> and SIZEUNITS.
>> Steve
>> >>> "ramya srinivasan" <hellomps at gmail.com> 09/07/08 10:51 AM >>>
>> Hi all,
>> * I want to draw a circle with the center clicked by the user on the
>> map.Can anyone help me??*
>> *Thanks*
