[mapserver-users] drawing a circle
Atul Dravid atul.dravid at iworktech.com
Tue Sep 9 01:02:08 EDT 2008
Dear Steve,
How do you change the radius of the circle dynamically ? Can you elaborate
more on this ?
My team is also trying to do the same thing like Ramya...
We have tried using the method Sucharita has suggested and it is working...
But it appears that your method may be simpler... But we are not able to
draw a circle with radius to be set dynamically...
Thanks,
--AD
On Tue, Sep 9, 2008 at 12:03 AM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> Create a layer in your mapfile like so:
> SYMBOL
>  NAME 'circle'
>  TYPE ELLIPSE
>  FILLED TRUE
>  POINTS 1 1 END
> END
> LAYER
>  NAME 'myPoiint'
>  TYPE POINT
>  STATUS OFF
>  CLASS
>    STYLE
>      COLOR 255 0 0
>      SIZE 15
>    END
>  END
> END
> Then in your script, the steps would be like so:
> 1) get the 'myPoint' layer
> 2) add a point feature to it
> 3) set the STATUS appropriately
> Now draw as normal. Assuming the point is in map coordinates you should see
> a red circle at the location
> you specified.
> Steve
> >>> On 9/8/2008 at 11:15 AM, in message
> <3702658f0809080915y38b42472le294cbda8e40b45e at mail.gmail.com>, "ramya
> srinivasan" <hellomps at gmail.com> wrote:
> > Hi,
> > iam using php/mapscript.I will have to display the point clicked by the
> user
> > on the map. This is my task.Can u pls help me
> > On Mon, Sep 8, 2008 at 9:18 PM, Steve Lime <Steve.Lime at dnr.state.mn.us
> >wrote:
> >> Can you explain a bit more about your environment (CGI vs. MapScript),
> >> context of the need etc...?
> >> The easiest path will likely involve a point layer that you'll populate
> >> dynamically (with the click coordinate) and then display that point with
> a
> >> circle symbol. You can scale that symbol appropriately using a style
> SIZE
> >> and SIZEUNITS.
> >> Steve
> >> >>> "ramya srinivasan" <hellomps at gmail.com> 09/07/08 10:51 AM >>>
> >> Hi all,
> >>  * I want to draw a circle with the center clicked by the user on the
> >> map.Can anyone help me??*
> >> *Thanks*
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080909/f1eeaf34/attachment.html
