Antwort: [MAPSERVER-USERS] Problems using filters with GEODATABASE
umn-ms at hydrotec.de
Tue Sep 9 02:01:26 EDT 2008
Hello
1. Remove the Filteritem-line
2. Change Filter to
FILTER (OTRAS_FORM = 'BANCO SUBMARINO' or OTRAS_FORM = 'HOYA SUBMARINA')
or to
FILTER (OTRAS_FORM IN ('BANCO SUBMARINO','HOYA SUBMARINA'))
Bye
Benedikt Rothe
BTW: I think, when Mapserver creates the SQL-Statement
(maporaclespatial.c/osFilteritem(...)) it should surround it
with braces. Combined with the spatial-filter mapserver creates
a Where-Clause of the form
"CondA OR CondB AND CondC".
IMHO: To make precedence to Oracle unambiguous clear, it should rather be
"(CondA OR CondB) AND CondC".
mapserver-users-bounces at lists.osgeo.org schrieb am 08.09.2008 23:34:13:
> Hi everyone!
> I´m trying to use filters connecting with a GDB. I type the following in
my
> map file:
> FILTERITEM "OTRAS_FORM"
> FILTER ('[OTRAS_FORM]' = 'BANCO SUBMARINO' or '[OTRAS_FORM]' = 'HOYA
> SUBMARINA')
> The thing is if I inactive those lines mapserver works perfectly....but,
of
> course, without filters.
> the error lines are:
> "[Thu Sep 04 15:15:17 2008].578000 msOracleSpatialLayerWhichShapes():
> OracleSpatial error. Error: ORA-00933: comando SQL no terminado
> correctamente
> . Query statement: SELECT OBJECTID, OTRAS_FORM, SHAPE FROM (SELECT
> OBJECTID, SHAPE, OTRAS_FORM FROM RN_GEODMG.INFO_OTRAS_FORMAS_MED_MAR)
WHERE
> OTRAS_FORM = '[OTRAS_FORM]' = 'BANCO SUBMARINO' or '[OTRAS_FORM]' =
'HOYA
> SUBMARINA' AND SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003, NULL,
> NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.
> SDO_ORDINATE_ARRAY(60298.583,3980828.85,649701.417,4298521.15)
> ),'querytype=window') = 'TRUE' . Check your data statement.
> [Thu Sep 04 15:15:17 2008].578000 msDrawMap(): Image handling error.
Failed
> to draw layer named 'morf_dv2'.
> [Thu Sep 04 15:15:22 2008].937000 msOracleSpatialLayerWhichShapes():
> correctamente"
> Thanks a million
> cheers
> View this message in context: http://www.nabble.com/Problems-using-
> filters-with-GEODATABASE-tp19309004p19309004.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080909/dd8cf4bf/attachment.html
