[mapserver-users] Precaching and opacity
ritesh ambastha
ritesh.linux at gmail.com
Wed Sep 10 16:11:29 EDT 2008
If you are using PNG24, then do keep Transparency as Alpha and
Antialiasing as True.
I hope you are using the current version of mapserver and ka-map.
Any reasons for not using AGG ?
Regards,
Ambastha
On Thu, Sep 11, 2008 at 1:37 AM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> Image type is PNG24. I've experimented with the Transparency and
> Opacity settings. If drawn without a precache, the map looks good.
> Precache seems to ignore the opacity. I haven't done anything with the
> antialiasing.
> -----Original Message-----
> From: group.ritesh at gmail.com [mailto:group.ritesh at gmail.com] On Behalf
> Of ritesh ambastha
> Sent: Wednesday, September 10, 2008 3:40 PM
> To: Bistrais, Bob
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Precaching and opacity
> Let us know the imagetype and outputformat defined in your map file.
> Have you set transparency and antialias correctly?
> Regards,
> Ambastha
> On Wed, Sep 10, 2008 at 2:04 AM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> wrote:
>> Please excuse my ignorance, I'm only starting to figure out the finer
>> points of precaching...
>> I built a map document for MS4W. Each layer file has an Opacity
> setting.
>> Without precaching, the map displays well in Ka-Map and in CGI view.
>> But after running the Precache.php, my opacity settings appear to be
> ignored.
>> Each layer (including line and point data) completely obscures the
>> previous layer.
>> Is there some setting in Precache, or elsewhere, that I missed? Any
>> other suggestions?
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
