[mapserver-users] WCS 1.1.0 support in MapServer 5.2?
Glenn Waldron
gwaldron at gmail.com
Thu Sep 11 12:01:31 EDT 2008
> Glenn,
> I would suggest ensuring that -DUSE_LIBXML2 appears in the compile lines
> as mapserver is building. I would suggest doing a make clean after the
> configure. I would suggest ensuring that you are really using the newly
> installed executable after rebuilding and installing it.
> It is *almost* certain you have just not done a clean enough rebuild and
> reinstall with the new options.
Frank,
You were correct; I was copying mapserv to the wrong place.
On a related note, I found what I believe to be a bug:
mapwcs11.c, line 1149
There should be no comma at the end of the line. The msIO_fprintf statement
results in junk; removing the comma fixes the problem.
Glenn
Glenn Waldron : Pelican Mapping : http://pelicanmapping.com :
+1.703.652.4791
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080911/4b330a4d/attachment.html
