[mapserver-users] Ed's Rules for the Best Raster Performance
Brent Fraser
bfraser at geoanalytic.com
Mon Sep 15 16:40:55 EDT 2008
I love it! I had some half-baked convoluted list-of-tileindexes idea; this is much better.
We may have to allow PROJECTION=AUTO for the tiles (in the case where the tiles are in UTM several zones), and allow the tile index to be in a different SRS (e.g geographic) than the tiles (I can't recall if this already implemented; I know it caused me a problem some years ago).
A elegant enhancement with great potential...
Brent
Steve Lime wrote:
> Interesting idea. This could take the form of a tile index with a couple of additonal columns, minscale and maxscale. Tiles would
> be grouped together by using common with those values. You could do interesting things like have high resolution data in
> some areas with other areas covered with lower resolution data over a broader range of scales. The whole layer could have it's
> own floor/ceiling but tiles would be handled individually.
> I wouldn't handle this as a new layer type, but rather by introducing parameters to indicate which columns to use, kinda like
> TILEITEM. Your pyramids would be defined in the tile index...
> I think the gdal tools would already support this nicely since they add to an index if it already exists so you could run those tools
> over mutliple datasets. Vector layers could also be handled this way, no reason you couldn't have 1 tile per scale range.
> Steve
>>>> On 9/15/2008 at 2:18 PM, in message <48CEB4F5.9020809 at geoanalytic.com>, Brent
> Fraser <bfraser at geoanalytic.com> wrote:
>> Jeff McKenna wrote:
>>> my quick comments:
>>> - adding overviews with GDAL's 'gdaladdo' utility is very important
>> In some cases. It depends on your data. As Ed once posted, it may be a
>> good idea to switch to external overviews and merge some of the files to
>> limit the number of file-opens Mapserver must do when the view is zoomed way
>> out.
>>> - I find your use of the word "pyramid" confusing (this seems to be a
>>> word that Arc* users are familiar with but has no real meaning in the
>>> MapServer world...I guess I've been on the "good" side for too long ha)
>> Not being an Arc* user I can't comment on it's origins. "Overview" is a
>> good alternative, but it doesn't seem to convey the same "multi-levelness" as
>> pyramids. For example to be able to display the Global Landsat Mosaic, I
>> created seven levels of a pyramid (each an external overview of the
>> higher-resolution below it).
>> Hmmm, may be the plural of overview is pyramid... :)
>> Hey Steve L., maybe we should have a "PYRAMID" Layer type, to replace a set
>> of scale-sensitive TILEINDEX Layers (this would help my
>> every-layer-is-exposed-in-WMS problem too:
>> http://trac.osgeo.org/mapserver/ticket/300).
>> Brent
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
