[mapserver-users] looking for mapserver non-MS4W binaries for IIS
J.J. Schlafley
jjschlafley at yahoo.com
Tue Sep 16 01:24:59 EDT 2008
I used this for MS4W and IIS.
http://mapserver.gis.umn.edu/docs/howto/setupiis
----- Original Message ----
To: mapserver-users at lists.osgeo.org
Sent: Tuesday, September 16, 2008 12:38:21 AM
Subject: [mapserver-users] looking for mapserver non-MS4W binaries for IIS
Hi there,
I read some tutorial on how to use Mapserver as CGI application on IIS,
here:
http://biometry.gis.umn.edu/tutorial/install.html
However i can't find package described on those tutorial, however i have
success using MS4W before, so it should be possible that binaries from
MS4W can be used on IIS based webserver, in this step i stucked:
---quote from above tutorial---
Copy the files from "C:\MapServer\lib" to C:\Windows\System or
C:\Winnt\System32, whichever is appropriate for your Windows version.
(Alternatively, you can edit your system PATH to include
"C:\MapServer\lib". In this way you don't have to copy the library files
to your system directory.) Move "C:\MapServer\Proj" to "C:\Proj". This is
required for projection support.
---end quote---
Where or what contents that should be on "lib" and "Proj" folders that
available on MS4W package (i have take alook there's no lib or Proj
directories there)
Many Thanks,
Dels
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080915/d42ca584/attachment.html
