[MAPSERVER-USERS] Debian Oracle10g OCI
Umberto Nicoletti umberto.nicoletti at gmail.com
Tue Sep 16 05:55:19 EDT 2008
I'm at a complete loss here. I assume there is a problem with your
oracle install.
did you run /etc/init.d/oracle-xe configure?
Umberto
2008/9/16  <dzizes451 at gmail.com>:
> Makefile generates without any problems, but when executing make command I
> receive:
> /usr/bin/ld: warning: libnnz10.so, needed by
> /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so, not
> found (try using -rpath or -rpath-link)
> /usr/lib/oracle/xe/app/oracle/product/10.2.0/server/lib/libclntsh.so:
> undefined reference to `nztSearchNZDefault'
> undefined reference to `nzosCipherSpecToStr'
> undefined reference to `nztwOpenWallet'
> undefined reference to `A_X931RandomInit'
> undefined reference to `nzosgpc_GetProtocolVer'
> undefined reference to `nzos_DisableClientAuthentication'
> undefined reference to `nzduui2_destroy_ui'
> ORACLE_HOME=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
> LD_LIBRARY_PATH=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server/bin
> PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
> LOGNAME=root
> Michał
> 2008/9/16 Umberto Nicoletti <umberto.nicoletti at gmail.com>
>> Revert configure to the previous oraclespatial setting and try:
>> export ORACLE_HOME=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
>> before configure.
>> Umberto
>> > Now I get:
>> > checking if OracleSpatial support requested... yes, user supplied
>> > ORACLE_HOME
>> > configure: error: Oracle Spatial: libclntsh.so not found.
>> > I enclose the config.log.
>> > Michał
>> >> try:
>> >> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0
>> >> otherwise post the config.log file.
>> >> Umberto
>> >> > Thanks for the tip!
>> >> > The Makefile looks like:
>> >> >  -------------- Compiler Info -------------
>> >> >   C compiler:                gcc -O2 -fPIC -Wall
>> >> >   C++ compiler:              g++ -O2 -fPIC -Wall
>> >> >   Debug:
>> >> >   Generic NINT:
>> >> >  -------------- Renderer Settings ---------
>> >> >   zlib support:              -DUSE_ZLIB
>> >> >   png support:
>> >> >   palette rgba png support:
>> >> >   jpeg support:
>> >> >   iconv support:             -DUSE_ICONV
>> >> >   AGG support:
>> >> >   AGG Freetype support:
>> >> >   Ming(flash) support:
>> >> >   PDFLib support:
>> >> >  -------------- Support Libraries ---------
>> >> >   Proj.4 support:            -DUSE_PROJ
>> >> >   Libxml2 support:
>> >> >   FriBidi support:
>> >> >   Curl support:              -DUSE_CURL
>> >> >   FastCGI support:
>> >> >   Threading support:         -DUSE_THREAD
>> >> >   GEOS support:
>> >> >  -------------- Data Format Drivers -------
>> >> >   native tiff support:
>> >> >   PostGIS support:
>> >> >   EPPL7 support:             -DUSE_EPPL
>> >> >   ArcSDE support:
>> >> >   OGR support:               -DUSE_OGR
>> >> >   GDAL support:              -DUSE_GDAL
>> >> >   Oracle Spatial support:    -DUSE_ORACLESPATIAL
>> >> >  -------------- OGC Services --------------
>> >> >   WMS Server:                -DUSE_WMS_SVR
>> >> >   WMS Client:                -DUSE_WMS_LYR
>> >> >   WFS Server:
>> >> >   WFS Client:                -DUSE_WMS_LYR
>> >> >   WCS Server:
>> >> >   SOS Server:
>> >> >  -------------- MapScript -----------------
>> >> >   PHP MapScript:             no
>> >> > the make command throws the following error:
>> >> > not
>> >> > ends with
>> >> > collect2: ld returned 1 exit status
>> >> > make: *** [shp2img] Error 1
>> >> > any ideas!
>> >> > Michał
>> >> >> Usign tiff AND gdal is not recommended, you'd better try these
>> >> >> options:
>> >> >> ./configure
>> >> >> -with-oraclespatial=/usr/lib/oracle/xe/app/oracle/product/10.2.0/server
>> >> >> -with-proj -with-wfsclient -with-wmsclient -with-gdal -with-ogr
>> >> >> -with-threads -with-freetype  -without-tiff -with-FastCGI
>> >> >> as for the expat error:
>> >> >> sudo apt-get install libexpat1 libexpat1-dev
>> >> >> Umberto
>> >> >> > Hi again,
>> >> >> > I've tried to compile mapserv executable with:
>> >> >> > ./configure
>> >> >> > -with-threads -with-freetype  -with-tiff -with-FastCGI
>> >> >> > and I receive this error:
>> >> >> > /usr/bin/ld: cannot find -lexpat
>> >> >> > Does anyone know what is wrong?
>> >> >> > Michał
>> >> >> > On Mon, Sep 15, 2008 at 3:16 PM, Dan Little <danlittle at yahoo.com>
>> >> >> > wrote:
>> >> >> >> Umberto is right, for Mapserver to connect to Oracle you need to
>> >> >> >> specify
>> >> >> >> that capability at compile time.  But for you ge tthat far I
>> >> >> >> think
>> >> >> >> you
>> >> >> >> need
>> >> >> >> to make sure that some of the basics work.
>> >> >> >> Also, if you cannot connect to Oracle via SQL*Plus (assuming the
>> >> >> >> binary
>> >> >> >> is
>> >> >> >> installed) you have other problems including but not limited to:
>> >> >> >> - needing to set the LD_LIBRARY_PATH to include all the
>> >> >> >> libraries.
>> >> >> >>  This
>> >> >> >> may also need to be done in Apache while running mapserver to
>> >> >> >> access
>> >> >> >> Oracle.
>> >> >> >> - needing to configure your TNSNAMES file.
>> >> >> >> - check firewall setting in order to make sure you can connect on
>> >> >> >> 1521
>> >> >> >> (or
>> >> >> >> whatever port you are using for Oracle).
>> >> >> >> Generally, when running an Oracle layer, you want to try the
>> >> >> >> following
>> >> >> >> diagnostic steps:
>> >> >> >> 1) Use SQL Developer to connect to the database (it has it's own
>> >> >> >> drivers
>> >> >> >> built in, so there's no software dependency issues).  This will
>> >> >> >> resolve
>> >> >> >> whether or not the databas is working.
>> >> >> >> 2) On the machine, try connecting with SQL Plus.  This will
>> >> >> >> determine
>> >> >> >> whether or not you have your client configured correctly.  Do not
>> >> >> >> move
>> >> >> >> on
>> >> >> >> until this works.
>> >> >> >> 3) Try and re-compile Mapserver with Oracle Spatial.  At the end
>> >> >> >> of
>> >> >> >> the
>> >> >> >> ./configure script there is an output screen, ensure that you see
>> >> >> >> Oracle is
>> >> >> >> turned on, otherwise scroll up in the screen and see what's
>> >> >> >> missing.
>> >> >> >> ----- Original Message ----
>> >> >> >> > From: Umberto Nicoletti <umberto.nicoletti at gmail.com>
>> >> >> >> > To: dzizes <dzizes451 at gmail.com>
>> >> >> >> > Cc: mapserver-users at lists.osgeo.org
>> >> >> >> > Sent: Monday, September 15, 2008 7:45:48 AM
>> >> >> >> > Subject: Re: [MAPSERVER-USERS] Debian Oracle10g OCI
>> >> >> >> > You have to recompile mapserver with the:
>> >> >> >> > --with-oraclespatial=[path to oracle home]
>> >> >> >> > option. That's all that is needed to enable oracle spatial
>> >> >> >> > support
>> >> >> >> > in
>> >> >> >> > mapserver.
>> >> >> >> > HTH,
>> >> >> >> > Umberto
>> >> >> >> > On Mon, Sep 15, 2008 at 2:05 PM, dzizes wrote:
>> >> >> >> > > Hi,
>> >> >> >> > > I've installed mapserver on Debian (lenny distribution). I've
>> >> >> >> > > managed
>> >> >> >> > > to
>> >> >> >> > > create mapfile based on shp data and successfully send a wms
>> >> >> >> > > request
>> >> >> >> > > to get
>> >> >> >> > > a map. I seems that mapserver works fine.
>> >> >> >> > > I've also installed oracle-ex and I can connect to my Oracle
>> >> >> >> > > via
>> >> >> >> > > sqlplus.
>> >> >> >> > > However, when I request wms (to a map file pointing to
>> >> >> >> > > Oracle10g) I
>> >> >> >> > > receive
>> >> >> >> > > the following:
>> >> >> >> > > msDrawMap(): Image handling error. Failed to draw layer named
>> >> >> >> > > 'test'.
>> >> >> >> > > msOracleSpatialLayerOpen(): OracleSpatial error.
>> >> >> >> > > OracleSpatial
>> >> >> >> > > is
>> >> >> >> > > not
>> >> >> >> > > supported
>> >> >> >> > > I've found that I need OCI installed and configured properly,
>> >> >> >> > > but
>> >> >> >> > > there is
>> >> >> >> > > no clear tutorial.
>> >> >> >> > > Please provide me a some step by step guide.
>> >> >> >> > > Greets,
>> >> >> >> > > Michal
>> >> >> >> > > View this message in context:
>> >> >> >> > http://www.nabble.com/Debian-Oracle10g-OCI-tp19491636p19491636.html
>> >> >> >> > > Sent from the Mapserver - User mailing list archive at
>> >> >> >> > > Nabble.com.
>> >> >> >> > > _______________________________________________
>> >> >> >> > > mapserver-users mailing list
>> >> >> >> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
