[mapserver-users] Ed's Rules for the Best Raster Performance
Bob Basques bob.b at gritechnologies.com
Tue Sep 16 16:26:47 EDT 2008
Hi All,
I work with Jim, so I suppose I should add some stuff here.
We use Jpegs for Aerial Photography only, and PNGs for everything else,
for the same reasons stated here.   I'll let Jim talk to the technical
stuff related to the pyramiding process as he put it all together into
an automated process.
Just to clear up some small points, we only store 1000x1000 pixel images
behind MapServer for serving of the raster data sets, no more than four
(4) of these source images should (in the majority of cases) need to be
accessed per web call.
bobb
pcreso at pcreso.com wrote:
> Hmmm.... the discussion here has only looked at jpgs & geotiffs.
> I tend to use PNG format, which I believe is less lossy than jpgs, & supports transparency, which has worked fine for small scale implementations.
> Can any experts here comment on the pros/cons of png vs jpg?
> Thanks,
>   Brent Wood
> --- On Wed, 9/17/08, Ed McNierney <ed at mcnierney.com> wrote:
>> From: Ed McNierney <ed at mcnierney.com>
>> Subject: Re: [mapserver-users] Ed's Rules for the Best Raster Performance
>> To: "Jeff Hoffmann" <jeff.hoffmann at gmail.com>
>> Cc: "Jim Klassen" <Jim.Klassen at ci.stpaul.mn.us>, "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>> Date: Wednesday, September 17, 2008, 3:45 AM
>> Jeff -
>> I'm not convinced, either, but I have never seen a
>> real-world test that has shown otherwise.  There haven't
>> been many such tests, but I have done them myself and
>> several others have done them as well and posted the results
>> on this list.  There may be tradeoffs which require a
>> different implementation - that's life in the real world
>> - but the data (the real, measured data, not theoretical
>> speculation) has always been consistent.
>> If you want to shrink the file size in this thought
>> experiment that's fine, but realize that you are thereby
>> increasing the number of files that need to be opened for a
>> random image request.  And each new open file incurs a
>> relatively high cost (directory/disk seek overhead, etc.);
>> those thousands or millions of JPEGs aren't just hard to
>> keep track of - they hurt performance.  I have been the
>> keeper of tens of millions of such files, and have seen some
>> of those issues myself.
>> The example I gave (and my other examples) are, however,
>> primarily intended to help people think about all the
>> aspects of the problem.  File access performance in an
>> application environment is a complex issue with many
>> variables and any implementation should be prototyped and
>> tested.  All I really care about is that you don't think
>> it's simple and you try to think through all the
>> consequences of an implementation plan.
>> I will also admit to being very guilty of not designing for
>> "low-moderate load" situations, as I always like
>> my Web sites to be able to survive the situation in which
>> they accidentally turn out to be popular!
>>     - Ed
>> On 9/16/08 11:21 AM, "Jeff Hoffmann"
>> <jeff.hoffmann at gmail.com> wrote:
>> Ed McNierney wrote:
>>> And remember that not all formats are created equal.
>> In order to
>>> decompress ANY portion of a JPEG image, you must read
>> the WHOLE file.
>>> If I have a 4,000x4,000 pixel 24-bit TIFF image
>> that's 48 megabytes,
>>> and I want to read a 256x256 piece of it, I may only
>> need to read one
>>> megabyte or less of that file. But if I convert it to
>> a JPEG and
>>> compress it to only 10% of the TIFF's size,
>> I'll have a 4.8 megabyte
>>> JPEG but I will need to read the whole 4.8 megabytes
>> (and expand it
>>> into that RAM you're trying to conserve) in order
>> to get that 256x256
>>> piece!
>> I have a feeling like I'm throwing myself into a
>> religious war, but here
>> goes. I think the problem that you have in your estimates
>> is that you're
>> using large (well, sort of large) jpegs. When you're
>> using properly
>> sized jpegs on modern servers at low-moderate load, you can
>> pretty much
>> disregard the processor time and memory issues, and just
>> compare on the
>> basis of the slowest component, disk access. 4000x4000 is
>> big & the
>> performance isn't going to be good (for the reasons you
>> mention), but he
>> never claimed to be using images that big. What he claimed
>> is that he's
>> using 1000x1000 jpegs. The 1000x1000 jpegs is pretty
>> critical because
>> it's that sweet spot where the decompress time is
>> small, the memory
>> demands manageable but the images are large enough that you
>> keep the
>> number of tiles down to a minimum for most uses. Those
>> jpegs might be in
>> the 200k size range, compared to a 256x256 block = 64k (x3
>> bands =192k?)
>> so he's reading a full 1000x1000 image in the disk
>> space of 1 256x256
>> block. If you're serving up 500x500 finished image,
>> you're using at
>> least 4 blocks in the geotiff, maybe 9 compared 1-4 with
>> the 1000x1000
>> jpeg. You could easily be spending 2x the time reading the
>> disk with
>> geotiff as you would be with jpegs. I haven't sat down
>> and done any side
>> by side tests, but I can see how they would be competitive
>> for certain
>> uses when you look at it that way. Of course there are
>> other issues like
>> lossy compression on top of lossy compression, plus
>> you've got to worry
>> about keeping track of thousands (millions?) of jpegs, but
>> they're
>> probably manageable tradeoffs. Oh, and you don't really
>> get the option
>> to have nodata areas with jpegs, either. There's
>> probably other
>> drawbacks, too, but I'm not convinced that performance
>> is one of them.
>> jeff
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080916/690c7c26/attachment.html
