[mapserver-users] rotation of vector symbol
Alberto Poggi
albpoggi at gmail.com
Wed Sep 17 04:58:40 EDT 2008
Ok, thanks, at least I know that is not my mistake.
You know a way to solve the problem?
2008/9/17 thomas bonfort <thomas.bonfort at gmail.com>:
> it's a known problem
> http://trac.osgeo.org/mapserver/ticket/2671
> cheers,
> thomas
> On Wed, Sep 17, 2008 at 10:26 AM, Alberto Poggi <albpoggi at gmail.com> wrote:
>> Hi.
>> Let me tell you about an issue of rotation of the vector symbols. I
>> found that in mapserver the rotation of these symbols does not follow
>> the classic rules that provide for the starting rotation in sequence
>> from east to the north, west and south. I published my work with
>> PMAPPER and MAPSERVER and I noticed that the rotation is done on the
>> other hand (east, south, west and north), and only on symbols of a
>> vector. This problem on the labelling does not exist and the rotation
>> is correct.
>> The layer referenced for symbol is a postgis table that contains a
>> field "rotazione" used by MapServer for the rotation of symbols. The
>> display of symbols is right but the rotation is done wrong.
>> This is the definition of my symbol:
>> SYMBOL
>> NAME "valvola"
>> TYPE vector
>> POINTS
>> 0 0
>> 1.5 1
>> 1.5 0
>> 0 1
>> 0 0
>> END
>> FILLED TRUE
>> END
>> and this is the notation in the mapfile:
>> LAYER
>> NAME "Valvole"
>> TYPE POINT
>> CONNECTIONTYPE postgis
>> CONNECTION "user=****** password=***** dbname=ACQUA host=localhost"
>> DATA "the_geom FROM valvole"
>> STATUS DEFAULT
>> MAXSCALE 5001
>> TOLERANCE 10
>> TOLERANCEUNITS pixels
>> PROJECTION
>> "init=epsg:32632"
>> END
>> METADATA
>> "DESCRIPTION" "Valvole"
>> "RESULT_FIELDS" "comune,localita"
>> "RESULT_HEADERS" "Comune,Località"
>> "LAYER_ENCODING" "UTF-8"
>> "ows_title" "Dati valvole"
>> END # Metadata
>> CLASS
>> NAME "Valvole"
>> STYLE
>> SYMBOL 'valvola'
>> COLOR 0 255 255
>> OUTLINECOLOR 0 0 0
>> ANGLE [rotazione]
>> SIZE 8
>> END
>> END
>> TEMPLATE void
>> END
>> It's me that something wrong or is a known problem? Thank you.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
