[mapserver-users] mapserver 5 TIFF displaying problem
Raivo Alla snaperski at gmail.com
Wed Sep 17 05:50:48 EDT 2008
Thank you for answering!
There's some additional information. Gdalinfo output:
Driver: GTiff/GeoTIFF
Files: 65812.tif
       65812.aux
Size is 5000, 5000
Coordinate System is:
LOCAL_CS["Estonia_1997_Estonia_National_Grid",
    UNIT["meters",1]]
Origin = (715000.500000000000000,6584999.500000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
  TIFFTAG_XRESOLUTION=2272.0896
  TIFFTAG_YRESOLUTION=2272.0896
  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
Image Structure Metadata:
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  715000.500, 6584999.500)
Lower Left  (  715000.500, 6579999.500)
Upper Right (  720000.500, 6584999.500)
Lower Right (  720000.500, 6579999.500)
Center      (  717500.500, 6582499.500)
Band 1 Block=5000x8 Type=Byte, ColorInterp=Red
  Metadata:
    LAYER_TYPE=athematic
Band 2 Block=5000x8 Type=Byte, ColorInterp=Green
  Metadata:
Band 3 Block=5000x8 Type=Byte, ColorInterp=Blue
  Metadata:
And from .map file:
IMAGETYPE PNG
 OUTPUTFORMAT
  NAME png
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE RGB
END
PROJECTION
     "init=epsg:4326"
END
METADATA
    WMS_TITLE "UMN MapServer Maa-ameti TEST"
    WMS_ABSTRACT "Mõeldud testimiseks"
    WMS_ACCESSCONSTRAINTS "none"
    WMS_SRS "EPSG:4326"
END
Could it be problem that coordinate systems does not match?
However, I remember it's written that Mapserver could do SRS transforming
on-the-fly.
On Wed, Sep 17, 2008 at 11:23 AM, Rahkonen Jukka
<Jukka.Rahkonen at mmmtike.fi>wrote:
>  Hi,
> Impossible to say with this information.  Much better possibilities to help
> you if you could send also the main MAP part of your mapfile including at
> lesast outputformat and projection, and the metadata sections.  Gdalinfo
> report about the image might be helpful as well.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Raivo Alla
> *Lähetetty:* 17. syyskuuta 2008 9:38
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] mapserver 5 TIFF displaying problem
>  Hello,
> I'm quite new using Mapserver and found myself struggling with this
> simple-looking problem:
> In my map file, there is layer defined as follows:
> LAYER
>  TYPE RASTER
>  NAME "raster"
>  STATUS ON
>  DATA "54653.tif"
> END
> The problem is, that this image is corrupted when I look at it in ArcMap -
> it contains strange black boxes and stripes. Original image is OK, so
> I guess the problem is somewhere in map file.
> .tfw file should be ok:
> 1.000000000000000
> 0.000000000000000
> 0.000000000000000
> -1.000000000000000
> 650000.500000000000000
> 6469999.500000000000000
> What could be the problem?
> Raivo Alla
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080917/6528fa48/attachment.html
