[mapserver-users] mapserver 5 TIFF displaying problem
Emerson, Gabe gemerson at WelshCo.com
Wed Sep 17 10:45:01 EDT 2008
Raivo,
I sometimes get odd artifacts showing up on my PNG24 maps as well. I don't know if it's related to your problem, but I believe mine is client-related based on its behavior, even though it happens on multiple computers and browsers.
Every now and then, my map comes out looking like this: https://netfiles.umn.edu/users/emers089/www/imgerror.jpg
It doesn't always look the same, sometimes  the map is greyed out or covered in mostly black, sometimes only part of the map is affected.
Since it's unpredictable and infrequent, I haven't been able to test very much. However, It clears itself immediately when I click anything on the page, or when I resize the browser window. That makes me think that my problem is related to client-side graphics drivers; the correct image is already in the browser, just hidden under the artifacting. I've been meaning to play around with driver updates, but it hasn't been enough of an issue.
-Gabe
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka
Sent: Wednesday, September 17, 2008 7:22 AM
To: Raivo Alla; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] mapserver 5 TIFF displaying problem
I'm sorry, I fear I can't help you further.  I'm sure that somebody else will go on with your problem soon.  There must be something odd in the image or in your Mapserver.  You could still try two things and try to find exact reason for the failure:
- use ready compiled Mapserver if you find such for your operating system
- test with another image from different source
-Jukka-
	Lähettäjä: Raivo Alla [mailto:snaperski at gmail.com]
	Lähetetty: 17. syyskuuta 2008 14:57
	Vastaanottaja: Rahkonen Jukka
	Aihe: Re: [mapserver-users] mapserver 5 TIFF displaying problem
	thank you but sadly it did'nt help.
	Changed the DRIVER and translated to GeoTiff, but the problem remained.
	Even after I changed my .map file projection to EPSG:3301 (same like that .tif file has) was the same picture there.
	If I zoom in/out, then the picture changes a bit ->
	http://picasaweb.google.com/snaperski/Ort#5246949911192681730
	Strange:)
	Raivo
	On Wed, Sep 17, 2008 at 2:27 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
	If all the clients show the same artifacts we can trust they come from the server.  For some reason it does not like your original image.  Try converting it to uncompressed geotiff image with gdal_translate
	gdal_translate -of GTiff 54653.tif 54653_basic.tif
	Make another layer from this new image, or edit your mapfile to use that instead of the original 54653.tif.  What happens? By the way, I believe it should read
	DRIVER "GD/PNG24"
	-Jukka-
		Lähetetty: 17. syyskuuta 2008 14:16
		Hei,
		thank you for advice!
		I changed .map a bit:
		IMAGETYPE png24
		OUTPUTFORMAT
		  NAME png24
		  DRIVER "GD/PNG"
		  MIMETYPE "image/png"
		  IMAGEMODE RGBA
		  EXTENSION "png"
		END
		output quality looks better, but that black-lined crap is still there:(
		I tried the same with uDig and Gaia WMS-clients, but it's the same.
		Raivo
		On Wed, Sep 17, 2008 at 1:51 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
		It's getting closer.  Image is now at least in a correct place?  Distortion can be due to ArcMAP, perhaps it does not like the outputformat you are using.  Next trials:
		- Have a try with another client software. like Quantum GIS, OpenJUMP, Cadcorp SIS map browser, or just your web browser.
		- Try changing outputformat.  I believe you will need to change it anyway, png is not good for aerial images.  Try png24 or jpeg instead.
		-Jukka-
			Lähetetty: 17. syyskuuta 2008 13:43
			Thank you,
			I added PROJECTION block to the layer, but unfortunately the same dance: output is corrupted as it could be seen here:
			http://picasaweb.google.com/snaperski/Ort#5246933992333025954
			Maybe I should compile mapserver without -with-tiff key?
			Raivo
			On Wed, Sep 17, 2008 at 1:03 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
			Tere.
			You have defined the output projection as epsg:4326 and by quick look it is OK in both map projection and WMS metadata.  However, your original image is in Estonian projection, but Mapserver does not know it automatically.  You need to add PROJECTION block to layer definitions as well.  Try editin your mapfile as follows:
			LAYER
			  TYPE RASTER
			  NAME "raster"
			  STATUS ON
			  DATA "54653.tif"
			PROJECTION
			   "init=epsg:3301"
			END  #end projection
			END #end layer
			I hope I guessed the epsg code right.
			-Jukka Rahkonen-
				Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Raivo Alla
				Lähetetty: 17. syyskuuta 2008 12:51
				Vastaanottaja: mapserver-users at lists.osgeo.org
				Thank you for answering!
				There's some additional information. Gdalinfo output:
				Driver: GTiff/GeoTIFF
				Files: 65812.tif
				       65812.aux
				Size is 5000, 5000
				Coordinate System is:
				LOCAL_CS["Estonia_1997_Estonia_National_Grid",
				    UNIT["meters",1]]
				Origin = (715000.500000000000000,6584999.500000000000000)
				Pixel Size = (1.000000000000000,-1.000000000000000)
				Metadata:
				  TIFFTAG_XRESOLUTION=2272.0896
				  TIFFTAG_YRESOLUTION=2272.0896
				  TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
				Image Structure Metadata:
				  COMPRESSION=LZW
				  INTERLEAVE=PIXEL
				Corner Coordinates:
				Upper Left  (  715000.500, 6584999.500)
				Lower Left  (  715000.500, 6579999.500)
				Upper Right (  720000.500, 6584999.500)
				Lower Right (  720000.500, 6579999.500)
				Center      (  717500.500, 6582499.500)
				Band 1 Block=5000x8 Type=Byte, ColorInterp=Red
				  Metadata:
				    LAYER_TYPE=athematic
				Band 2 Block=5000x8 Type=Byte, ColorInterp=Green
				  Metadata:
				Band 3 Block=5000x8 Type=Byte, ColorInterp=Blue
				  Metadata:
				And from .map file:
				IMAGETYPE PNG
				 OUTPUTFORMAT
				  NAME png
				  DRIVER "GD/PNG"
				  IMAGEMODE RGB
				END
				PROJECTION
				     "init=epsg:4326"
				END
				METADATA
				    WMS_TITLE "UMN MapServer Maa-ameti TEST"
				    WMS_ABSTRACT "Mõeldud testimiseks"
				    WMS_ACCESSCONSTRAINTS "none"
				    WMS_SRS "EPSG:4326"
				END
				Could it be problem that coordinate systems does not match?
				However, I remember it's written that Mapserver could do SRS transforming on-the-fly.
				On Wed, Sep 17, 2008 at 11:23 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
				Impossible to say with this information.  Much better possibilities to help you if you could send also the main MAP part of your mapfile including at lesast outputformat and projection, and the metadata sections.  Gdalinfo report about the image might be helpful as well.
				-Jukka Rahkonen-
					Lähetetty: 17. syyskuuta 2008 9:38
					Aihe: [mapserver-users] mapserver 5 TIFF displaying problem
					Hello,
					I'm quite new using Mapserver and found myself struggling with this simple-looking problem:
					In my map file, there is layer defined as follows:
					LAYER
					 TYPE RASTER
					 NAME "raster"
					 STATUS ON
					 DATA "54653.tif"
					END
					The problem is, that this image is corrupted when I look at it in ArcMap - it contains strange black boxes and stripes. Original image is OK, so
					I guess the problem is somewhere in map file.
					.tfw file should be ok:
					1.000000000000000
					0.000000000000000
					0.000000000000000
					-1.000000000000000
					650000.500000000000000
					6469999.500000000000000
					What could be the problem?
					Raivo Alla
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080917/c89f902e/attachment-0001.html
