[mapserver-users] mapserver 5 TIFF displaying problem
Raivo Alla
snaperski at gmail.com
Thu Sep 18 02:28:21 EDT 2008
Jukka, thank you very much for discussion, it was helpful. For now I found
what was wrong.
Gabe, maybe it's useful for you too:
my mapserv compilation was both with --with-gdal and --with-tiff, when I
recompiled it removing native TIFF support (--without-tiff),
then this recompilation was successful:)
Have a nice day,
Raivo
On Wed, Sep 17, 2008 at 5:45 PM, Emerson, Gabe <gemerson at welshco.com> wrote:
> Raivo,
> I sometimes get odd artifacts showing up on my PNG24 maps as well. I don't
> know if it's related to your problem, but I believe mine is client-related
> based on its behavior, even though it happens on multiple computers and
> browsers.
> Every now and then, my map comes out looking like this:
> https://netfiles.umn.edu/users/emers089/www/imgerror.jpg
> It doesn't always look the same, sometimes the map is greyed out or
> covered in mostly black, sometimes only part of the map is affected.
> Since it's unpredictable and infrequent, I haven't been able to test very
> much. However, It clears itself immediately when I click anything on the
> page, or when I resize the browser window. That makes me think that my
> problem is related to client-side graphics drivers; the correct image is
> already in the browser, just hidden under the artifacting. I've been meaning
> to play around with driver updates, but it hasn't been enough of an issue.
> -Gabe
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Rahkonen Jukka
> *Sent:* Wednesday, September 17, 2008 7:22 AM
> *To:* Raivo Alla; mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] mapserver 5 TIFF displaying problem
> I'm sorry, I fear I can't help you further. I'm sure that somebody else
> will go on with your problem soon. There must be something odd in the image
> or in your Mapserver. You could still try two things and try to find exact
> reason for the failure:
> - use ready compiled Mapserver if you find such for your operating system
> - test with another image from different source
> -Jukka-
> *Lähettäjä:* Raivo Alla [mailto:snaperski at gmail.com]
> *Lähetetty:* 17. syyskuuta 2008 14:57
> *Vastaanottaja:* Rahkonen Jukka
> *Aihe:* Re: [mapserver-users] mapserver 5 TIFF displaying problem
> Hi,
> thank you but sadly it did'nt help.
> Changed the DRIVER and translated to GeoTiff, but the problem remained.
> Even after I changed my .map file projection to EPSG:3301 (same like that
> .tif file has) was the same picture there.
> If I zoom in/out, then the picture changes a bit ->
> http://picasaweb.google.com/snaperski/Ort#5246949911192681730
> Strange:)
> Raivo
> On Wed, Sep 17, 2008 at 2:27 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> wrote:
> Hi,
> If all the clients show the same artifacts we can trust they come from the
> server. For some reason it does not like your original image. Try
> converting it to uncompressed geotiff image with gdal_translate
> gdal_translate -of GTiff 54653.tif 54653_basic.tif
> Make another layer from this new image, or edit your mapfile to use that
> instead of the original 54653.tif. What happens? By the way, I believe it
> should read
> DRIVER "GD/PNG24"
> -Jukka-
> *Lähetetty:* 17. syyskuuta 2008 14:16
> Hei,
> thank you for advice!
> I changed .map a bit:
> IMAGETYPE png24
> OUTPUTFORMAT
> NAME png24
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> END
> output quality looks better, but that black-lined crap is still there:(
> I tried the same with uDig and Gaia WMS-clients, but it's the same.
> Raivo
> On Wed, Sep 17, 2008 at 1:51 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> wrote:
> Hi,
> It's getting closer. Image is now at least in a correct place? Distortion
> can be due to ArcMAP, perhaps it does not like the outputformat you are
> using. Next trials:
> - Have a try with another client software. like Quantum GIS, OpenJUMP,
> Cadcorp SIS map browser, or just your web browser.
> - Try changing outputformat. I believe you will need to change it anyway,
> png is not good for aerial images. Try png24 or jpeg instead.
> -Jukka-
> *Lähetetty:* 17. syyskuuta 2008 13:43
> Thank you,
> I added PROJECTION block to the layer, but unfortunately the same dance:
> output is corrupted as it could be seen here:
> http://picasaweb.google.com/snaperski/Ort#5246933992333025954
> Maybe I should compile mapserver without -with-tiff key?
> Raivo
> On Wed, Sep 17, 2008 at 1:03 PM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> wrote:
> Tere.
> You have defined the output projection as epsg:4326 and by quick look it is
> OK in both map projection and WMS metadata. However, your original image is
> in Estonian projection, but Mapserver does not know it automatically. You
> need to add PROJECTION block to layer definitions as well. Try editin your
> mapfile as follows:
> LAYER
> TYPE RASTER
> NAME "raster"
> STATUS ON
> DATA "54653.tif"
> PROJECTION
> "init=epsg:3301"
> END #end projection
> END #end layer
> I hope I guessed the epsg code right.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Raivo Alla
> *Lähetetty:* 17. syyskuuta 2008 12:51
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> Thank you for answering!
> There's some additional information. Gdalinfo output:
> Driver: GTiff/GeoTIFF
> Files: 65812.tif
> 65812.aux
> Size is 5000, 5000
> Coordinate System is:
> LOCAL_CS["Estonia_1997_Estonia_National_Grid",
> UNIT["meters",1]]
> Origin = (715000.500000000000000,6584999.500000000000000)
> Pixel Size = (1.000000000000000,-1.000000000000000)
> Metadata:
> TIFFTAG_XRESOLUTION=2272.0896
> TIFFTAG_YRESOLUTION=2272.0896
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> COMPRESSION=LZW
> INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left ( 715000.500, 6584999.500)
> Lower Left ( 715000.500, 6579999.500)
> Upper Right ( 720000.500, 6584999.500)
> Lower Right ( 720000.500, 6579999.500)
> Center ( 717500.500, 6582499.500)
> Band 1 Block=5000x8 Type=Byte, ColorInterp=Red
> Metadata:
> LAYER_TYPE=athematic
> Band 2 Block=5000x8 Type=Byte, ColorInterp=Green
> Metadata:
> Band 3 Block=5000x8 Type=Byte, ColorInterp=Blue
> Metadata:
> And from .map file:
> IMAGETYPE PNG
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> IMAGEMODE RGB
> END
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> WMS_TITLE "UMN MapServer Maa-ameti TEST"
> WMS_ABSTRACT "Mõeldud testimiseks"
> WMS_ACCESSCONSTRAINTS "none"
> WMS_SRS "EPSG:4326"
> END
> Could it be problem that coordinate systems does not match?
> However, I remember it's written that Mapserver could do SRS transforming
> on-the-fly.
> On Wed, Sep 17, 2008 at 11:23 AM, Rahkonen Jukka <
> Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Impossible to say with this information. Much better possibilities to help
> you if you could send also the main MAP part of your mapfile including at
> lesast outputformat and projection, and the metadata sections. Gdalinfo
> report about the image might be helpful as well.
> -Jukka Rahkonen-
> *Lähetetty:* 17. syyskuuta 2008 9:38
> *Aihe:* [mapserver-users] mapserver 5 TIFF displaying problem
> Hello,
> I'm quite new using Mapserver and found myself struggling with this
> simple-looking problem:
> In my map file, there is layer defined as follows:
> LAYER
> TYPE RASTER
> NAME "raster"
> STATUS ON
> DATA "54653.tif"
> END
> The problem is, that this image is corrupted when I look at it in ArcMap -
> it contains strange black boxes and stripes. Original image is OK, so
> I guess the problem is somewhere in map file.
> .tfw file should be ok:
> 1.000000000000000
> 0.000000000000000
> 0.000000000000000
> -1.000000000000000
> 650000.500000000000000
> 6469999.500000000000000
> What could be the problem?
> Raivo Alla
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080918/17503c28/attachment-0001.html
