[mapserver-users] geomfromtext (POSTGIS) in C# or other language...
Tamas Szekeres szekerest at gmail.com
Thu Sep 18 17:48:29 EDT 2008
or wkb (Well-Known Binary) what I wanted to say ;-)
http://dev.mysql.com/doc/refman/5.0/en/gis-wkb-format.html
Tamas
2008/9/18 Tamas Szekeres <szekerest at gmail.com>:
> 2008/9/18 Paul james <pauljame at gmail.com>:
>> I got a point from postgis in this format :
>> 010100000000000000000059400000000000005940
> It smells like a wkt geometry representation in hexstring format. You
> should convert this into a binary array and then use
> Geometry.CreateFromWkb, something like (untested):
> // allocate byte array based on half of string length
> byte[] bytes = new byte[(strInput.Length) / 2];
> // loop through the string - 2 bytes at a time converting it to
> decimal equivalent and store in byte array
> int i = 0, x= 0;
> while (strInput.Length > i + 1)
>    long lngDecimal = Convert.ToInt32(strInput.Substring(i, 2), 16);
>    bytes[x] = Convert.ToByte(lngDecimal);
>    i = i + 2;
>    ++x;
> Geometry geom = Geometry.CreateFromWkb(bytes);
> I wonder if there is some support to this kind of string conversion in
> the .NET FW class library (something like the BitConverter class) that
> I'm not aware of. Let me know if you can do it easier.
> Best regards,
> Tamas
