[mapserver-users] Labelling problem using mapserver withka-map
DI. Susanne Kalliany susanne.kalliany at tefis.at
Fri Sep 19 09:36:48 EDT 2008
Dear mapserver-community,
I already had some discussion on my particular problem under the
thread "Ok, one more labeling sample...", but even Steve Lime
had no solution which will work in any case. His last statement was:
> Ka-map is DHTML layer driven so you're definitely seeing the side
> effects of overlaying antialiased, transparent
> output on a background. The anti-aliasing occurs on a white background
> in the vector map which is why you see
> the white artifacts around your text. I'm not sure there is a perfect
> fix, variable opacity with 24-bit out put is the
> answer but not all browsers support it.
Does anybody have experience in this field?
My first statement was:
How can I get rid of the white "shadows" accompanying all letters ?
http://www.nabble.com/file/p19570283/SNAG-000.jpg
Here is the signifanct part of my map-file:
LAYER
   NAME Kataster_region
   GROUP Kataster
   STATUS OFF
   MAXSCALE 300000
   TYPE POLYGON
   DATA 'd:/ewald/Kataster_OOE/45416GST'
   LABELITEM 'GNR'
   CLASS
      STYLE
         OUTLINECOLOR 255 0 255
         WIDTH 1
      END
      LABEL
         TYPE TRUETYPE
         FONT 'sans'
         SIZE 8
         POSITION cc
         Color 0 0 0
      END
   END
   TEMPLATE 'dummy.html'
END
thanks, Susanne
View this message in context:
http://www.nabble.com/Labelling-problem-using-mapserver-with-ka-map-tp195702
83p19570283.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
