[mapserver-users] Using Fast CGI with MapServer to alleviate poor performance
James Perrins james.perrins at gmail.com
Sat Sep 20 03:39:07 EDT 2008
A couple of issues / tips we have found in this sort of scenario.
1) Edit your epsg file to contain only the projections you want - this
can make a big difference - presumably because its doind a slow string
search each time
2) If using OpenLayers (or google maps etc) - the tiling sends
multiple requests to the WMS server.  If you are using IE in
particular - this restricts you to 2 concurent threads to any one
server - mean9ing that your (say) 16 tile requests can only be
processed 2 at a time.  Firefox has a similar restriction by default -
but you can override it.  You can see this at work using Firefox with
a tool like firebug.
We foun it was much much quicker if you can change yout application to
request a single WMS tile for the whol map rather than individual
256x256 tiles.  Obviously this may have implications if you were
trying to cache tiles etc - but if not its massively quicker
HTH
James
On Wed, Sep 17, 2008 at 4:40 PM, John Westwood <John.Westwood at port.ac.uk> wrote:
> Hi,
> I am trying to use fast_cgi with MapServer, specifically mod_fcgid on SLES 10.2.
> I have mod_fcgid correctly set up within Apache because it works with another FCGI application (IIPImage).
> I have successfully compiled MapServer 5.2 with fast_cgi support. I used this page to help me:
> http://mapserver.gis.umn.edu/docs/howto/fastcgi
> However, when I try to use MapServer with mod_fcgid I receive the following error:
> The server encountered an internal error and was unable to complete your request
> Error message: Premature end of script headers: mapserv
> I am really lost as to what the problem could be; the non fast_cgi version of MapServer that I compiled worked fine. Perhaps it is something to do with setting the LD_LIBRARY_PATH in the mod_fcgid.conf file?
> At the moment I have it set as follows:
> DefaultInitEnv LD_LIBRARY_PATH "/usr/lib:/usr/local/lib:/usr/lib/postgresql"
> The reason I am trying to get MapServer to work with fast_cgi is because I am experiencing poor performance with OpenLayers. I believe that OpenLayers starts a new MapServer instance for each tile request, thus causing an unnecessary overhead. Am I correct?
> I will also be using Tilecache, but my experiments have also found this to be slow. It is currently set up to use mod_python. The hardware we are running on is a dual quad core (eight cores in total) Xeon . So it shouldn't be slow!
> I would greatly appreciate any help on getting MapServer to work with fast_cgi . I would also welcome any comments regarding performance issues with OpenLayers / MapServer / Tilecache .
> Thanks very much,
> John Westwood
> Great Britain Historical GIS Project
> mapserver-users at lists.osgeo.org
Dr James Perrins
exeGesIS SDM Ltd
Great House Barn
New Street, Talgarth
Powys LD3 0AH.
Direct Line: 01646 686650
Tel: 01874 711145
Fax: 01874 711156
Email: JamesP at esdm.co.uk
This E-mail and any files transmitted with it are private and intended
solely for the use of the individual or entity to whom they are
addressed. If you are not the intended recipient, the E-mail and any
files have been transmitted to you in error and any copying,
distribution or other use of the information contained in them is
strictly prohibited.
Nothing in this E-mail message amounts to a contractual or other legal
commitment on the part of exeGesIS SDM Ltd unless confirmed by a
signed communication.
exeGesIS SDM Ltd will make every effort to keep its network free of
viruses. However, the recipient of this message will need to scan this
message, and any attachments, for viruses, as exeGesIS SDM Ltd can
take no responsibility for any computer virus that might be
transferred by this e-mail.
