[mapserver-users] Mapserver and GDB files
Raivo Alla
snaperski at gmail.com
Tue Sep 23 01:20:18 EDT 2008
Thank you all very much for answers.
I am working on a project, where all data is in .gdb files and styles in
ArcGIS .lyr format.
I guess both - getting .gdb and .lyr files working in mapserver environment
- are at the moment not possible?
So I must convert convert .gdb files (using FME maybe?) to some readable
format like shapefiles (if possible) and
just type manually mapserver symbology files... uhh.
Raivo
On Mon, Sep 22, 2008 at 7:19 PM, William Kyngesburye
<woklist at kyngchaos.com>wrote:
> On Sep 22, 2008, at 9:59 AM, Frank Warmerdam wrote:
> Fawcett, David wrote:
>>> .gdb files are ESRI's new File Geodatabase proprietary format. I am
>>> quite sure that OGR/FWTools does not support it.
>> David,
>> Ah thanks. Indeed they are not supported and it is hard to imagine they
>> will be supported for a while. ESRI has indicated in the past that they
>> intend to provide an open mechanism to access the file geodatabase and
>> that
>> is still likely to happen at some point. However, I think this would be
>> quite a few months away at best.
> Hmmm, and if ESRI provides it, then, like SDE, it probably won't be
> available for OSX (or other linux platforms?). Bleh.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080923/ca926e72/attachment.html
