AW: AW: [mapserver-users] Oracle Spatial + MS 5.2.0: No drawing ofcertain objects
Schönhammer, Herbert Schoenhammer.Herbert at Regensburg.de
Tue Sep 23 02:40:17 EDT 2008
Hello Paul, hello list,
now the circumference of those polygons is rendered correct. But (unfortenately) only parts of the area are filled with the polygon-color.
Imagine, that all points of the oracle-geometry-object are connected by straight-lines (instead of arcs). The inner area of this outline is not rendered in the polygon-color.
The segment archs between this outline and the arcs of the circumference are filled with the correct color.
If there is a straight line in the circumference, the area is filled correct !
(See the little gif-examples of the appendix, if it is allowed to upload appendixes to the list !)
There is no difference using driver gd or agg !
greetings Herbert
>-----Ursprüngliche Nachricht-----
>Von: Paul Ramsey [mailto:pramsey at cleverelephant.ca]
>Gesendet: Montag, 22. September 2008 18:17
>An: Steve Lime
>Cc: mapserver-users at lists.osgeo.org; Schönhammer, Herbert
>Betreff: Re: AW: [mapserver-users] Oracle Spatial + MS 5.2.0:
>Should work, methinks.
>                       break;
>+                  case 32: /* simple polygon with only arcs
>for bounds */
>+                      osArcPolygon(hand, shape, obj, ord_start,
>ord_end, points, data3d);
>+                      shape->type = MS_SHAPE_POLYGON;
>+                      break;
>                   case 33: /* rectangle defined by 2 points */
>On Mon, Sep 22, 2008 at 6:55 AM, Steve Lime
><Steve.Lime at dnr.state.mn.us> wrote:
>> The shape->type value needs to be set to MS_SHAPE_POLYGON I believe.
>> I've not looked at where
>> Paul's patch sits in the source though so I don't know where
>that needs
>> to happen. Perhaps as the
>> second line in each of the cases of the patch?
>>  e.g. shape->type = MS_SHAPE_POLYGON;
>> Steve
>>>>> Schönhammer, Herbert <Schoenhammer.Herbert at Regensburg.de> 09/22/08
>> 2:43 AM >>>
>> Hallo Paul,
>> using this patch, mapserver is not ignoring those polygons anymore
>> (polygons, which exists ONLY of a connected sequence of circular arcs
>> that closes on itself).
>> But instead of rendering those polygons, I get know an error message:
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'stgk_gebaeude_orcl'.
>> msDrawShape(): General error message. Only polygon shapes
>can be drawn
>> using a POLYGON layer definition.
>> The first step for rendering those polgons is done:
>Mapserver recognizes
>> the polygons !
>> Can I do anything else ?
>> Greetings
>> Herbert
>> "polygons, which exists ONLY of
>>>a connected sequence of circular arcs that closes on itself
>>>Gesendet: Freitag, 19. September 2008 16:40
>>>An: Schönhammer, Herbert
>>>Cc: Mapserver-users (mapserver-users at lists.osgeo.org)
>>>Betreff: Re: [mapserver-users] Oracle Spatial + MS 5.2.0: No
>>>drawing of certain objects
>>>Try the following completely untested patch:
>>>Index: maporaclespatial.c
>>>--- maporaclespatial.c  (revision 7827)
>>>+++ maporaclespatial.c  (working copy)
>>>@@ -1476,6 +1476,9 @@
>>>                   case 31: /* simple polygon with n points, last
>>>point equals the first one */
>>>                       osClosedPolygon(hand, shape, obj, ord_start,
>>>ord_end, points, elem_type, data3d);
>>>                       break;
>>>for bounds */
>>>+                      break;
>>>                       osRectangle(hand, shape, obj, ord_start,
>>>ord_end, points, point5, data3d);
>>>                       break;
>>>On Fri, Sep 19, 2008 at 3:20 AM, Schönhammer, Herbert
>>><Schoenhammer.Herbert at regensburg.de> wrote:
>>>> Hallo Paul,
>>>> 1.) Yes, there is no difference in behavior between the old
>>>and new mapserver versions.
>>>> 2.) Yes and No. In detail:
>>>> 2a) If there is at most ONE straight line in the polygon,
>>>mapserver renders this polygon correct, even if there is a
>>>curved segement (arc) in the polygon. For example this is a
>>>church, which contains three arcs in the polygon (triple
>>>11,2,2 and 31,2,2 and 51,2,2). This polygon is rendered correct.
>>>> INSERT INTO AX_GEBAEUDE (FID,GEOM) VALUES
>>>(14080503,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>o_array(1,1005,7,1,2,1,11,2,2,15,2,1,31,2,2,35,2,1,51,2,2,55,2,
>>>1),mdsys.sdo_ordinate_array(4506867.81,5430890.76,4506872.05,54
>>>30889.72,4506881.01,5430887.51,4506881.58,5430889.82,4506883.14
>>>,5430896.16,4506937.22,5430883.9,4506941.09222415,5430884.75129
>>>585,4506943.86,5430887.59,4506948.31,5430886.72,4506947.53,5430
>>>882.98,4506950.45,5430882.37,4506950.02,5430880.3,4506955.17,54
>>>30879.23,4506955.58,5430881.2,4506958.35,5430880.62,4506959.21,
>>>5430884.73,4506961.57385865,5430886.53782314,4506960.13,5430889
>>>.14,4506960.94,5430893,4506957.92,5430893.63,4506958.4,5430896.
>>>12,4506953.2,5430897.12,4506952.74,5430894.72,4506950.1,5430895
>>>.27,4506949.23,5430891.12,4506944.73,5430892,4506942.9045371,54
>>>30896.27675424,4506939.38,5430899.31,4506893.36,5430909.55,4506
>>>886.79,5430911.01,4506888.96,5430919.81,4506882.98,5430921.28,4
>>>506874.83,5430923.28,4506874.09,5430920.3,4506872.55,5430914.03
>>>,4506866.92,5430915.42,4506864.74,5430915.95,4506861.35,5430902
>>>.17,4506870.09,5430900.02,4506867.81,5430890.76)));
>>>> 2b) Mapserver does not render polygons, which exis>> Greetings
>>>> Herbert
>>>>>Gesendet: Donnerstag, 18. September 2008 16:35
>>>>>So, to confirm, there is now no difference in behavior between your
>>>>>old and new mapserver installations?
>>>>>However, the old and new installations share an inability to render
>>>>>polygons that include curved boundaries?
>>>>>P.
>>>>>On Thu, Sep 18, 2008 at 3:14 AM, Schönhammer, Herbert
>>>>>> Hallo Paul,
>>>>>> (I needed some time because new hardware, ...)
>>>>>> Okay: First of all:
>>>>>> The reported NEW DIFFICULTIES are not reproducable any more.
>>>>>I really don't know what happened. But LINESTRINGS made up of
>>>>>a connected sequence of circular arcs ARE DRAWN by mapserver.
>>>>>> The old problem still exists.
>>>>>> POLYGONS made up of a connected sequence of circular arcs
>>>>>ARE NOT DRAWN by mapserver. No error message.
>>>>>> I have made a config error in my mapfile. So I could get an
>>>>>error message from mapserver. In this error message the
>>>>>SQL-statement sent to the oracle database is:
>>>>>> SELECT fid, geom FROM AX_GEBAEUDE WHERE SDO_FILTER( geom,
>>>>>MDSYS.SDO_GEOMETRY(2003, 82032,
>>>>>NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARR
>>>>>AY(4505602.25,5430841.31,4505622.97,5430856.39)
>>>>>),'querytype=window') = 'TRUE'
>>>>>> When i submit this SQL direct to the databse I get 4
>>>geometries back.
>>>>>> Two POLYGONS made up of straight line segements.
>>>>>> Two POLYGONS made up of a connected sequence of circular arcs.
>>>>>> The polygons with straight line segments are drawn, the
>>>>>polygons made up of a connected sequence of circular arcs are
>>>>>not drawn.
>>>>>> I have exported these objects from my database:
>>>>>> The drawn polygons are:
>>>>>(14079074,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>>>o_array(1,1003,1),mdsys.sdo_ordinate_array(4505658.59,5430772.1
>>>>>7,4505643.27,5430803.04,4505634.39,5430798.05,4505625.41,543081
>>>>>4,4505619.34,5430810.5898,4505607.9,5430830.95,4505607.4,543083
>>>>>0.7,4505600.29,5430845.02,4505511.2,5430801.08,4505534.42,54307
>>>>>54.01,4505552.34,5430762.86,4505569.51,5430728.08,4505658.59,54
>>>>>30772.17)));
>>>>>(14079078,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>>>o_array(1,1003,1),mdsys.sdo_ordinate_array(4505643.27,5430803.0
>>>>>4,4505643.85,5430803.37,4505644.39,5430803.67,4505644.34,543080
>>>>>3.76,4505635.46,5430819.49,4505633.64,5430822.73,4505619.68,543
>>>>>0847.46,4505609.69,5430841.9199,4505613.95,5430834.36,4505625.4
>>>>>1,5430814,4505634.39,5430798.05,4505643.27,5430803.04)));
>>>>>> The polygons which are not drawn are:
>>>>>(14079126,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>>>o_array(1,1003,2),mdsys.sdo_ordinate_array(4505611.03,5430848.5
>>>>>5,4505611.03,5430845.19,4505614.39,5430845.19,4505614.39,543084
>>>>>8.55,4505611.03,5430848.55)));
>>>>>(14079128,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>>>o_array(1,1003,2),mdsys.sdo_ordinate_array(4505615.64,5430849.9
>>>>>,4505615.64,5430847.3,4505618.24,5430847.3,4505618.24,5430849.9
>>>>>,4505615.64,5430849.9)));
>>>>>> All polygons are GTYPE=2003 in SRID=82032. All POLYGONS are
>>>>>SDO_ETYPE=1003.
>>>>>> The POLYGONS with SDO_INTERPRETATION = 1 are drawn.
>>>>>> The POLYGONS with SDO_INTERPRETATION = 2 are not drawn.
>>>>>> greetings
>>>>>> Herbert
>>>>>>>Gesendet: Donnerstag, 11. September 2008 19:07
>>>>>>>Cc: Mapserver-users (ma>>>>>Betreff: Re:
>>>>>>>Could you do a bit more legwork and see if the problem
>>>appears at the
>>>>>>>transition to 5.0 or the transition to 5.2? From there we
>>>>>can probably
>>>>>>>find the code change that caused it.
>>>>>>>P.
>>>>>>>On Wed, Sep 10, 2008 at 7:03 AM, Schönhammer, Herbert
>>>>>>>> Hi list,
>>>>>>>> ( I had a similar discussion using Mapserver 4.10.x and
>>>>>>>Oracle Spatial 9i in
>>>>>>>> May 2007. But the problems changed using Mapserver 5.2.0 .).
>>>>>>>> The new environmet:
>>>>>>>> Server SLES10
>>>>>>>> Mapserver 5.2.0
>>>>>>>> Oracle OCI - Interface used with Oracle 11-Client-Software
>>>>>>>> DB-Server Windows 2xxx
>>>>>>>> Oracle Spatial 10g
>>>>>>>> The new problem :
>>>>>>>> Line strings made up of a connected sequence of circular
>>>>>>>arcs ARE NOT DRAWN.
>>>>>>>> No error message is generated by mapserver, but the objects
>>>>>>>are not shown in
>>>>>>>> the map.
>>>>>>>> Example:
>>>>>>>> INSERT INTO AX_BES_GEBLINIE (FID,GEOM) VALUES
>>>>>>>(14196363,mdsys.sdo_geometry(2002,82032,null,mdsys.sdo_elem_inf
>>>>>>>o_array(1,2,2),mdsys.sdo_ordinate_array(4512474.1948,5426555.09
>>>>>>>79,4512473.3318,5426554.2349,4512474.1948,5426553.3719,4512475.
>>>>>>>0578,5426554.2349,4512474.1948,5426555.0979)));
>>>>>>>> (Background:
>>>>>>>> In my mailing from May 2007 I reported that these
>>>Objects are drawn
>>>>>>>> correctly by mapserver. This statement is indeed
>>>>>>>reproducable correct using
>>>>>>>> mapserver 4.10.x. This is independent from the used oracle
>>>>>>>version ( 9i or
>>>>>>>> 10g ).
>>>>>>>> Now, using mapserver 5.2.0 these objects are not drawn
>>>>>>>anymore. No error
>>>>>>>> message is produced. This is also independent from the used
>>>>>>>oracle version (
>>>>>>>> 9i or 10g ). )
>>>>>>>> The old problem:
>>>>>>>> Polygons  made up of a connected sequence of circular arcs
>>>>>>>ARE NOT DRAWN. No
>>>>>>>> error message is generated by mapserver, but the objects are
>>>>>>>not shown in
>>>>>>>> the map.
>>>>>>>> (This problem was already reported in May 2007. The
>>>>>>>behaviour did not change
>>>>>>>> from mapserver 4.10.x to 5.2.0)
>>>>>>>> Example:
>>>>>>>(14079065,mdsys.sdo_geometry(2003,82032,null,mdsys.sdo_elem_inf
>>>>>>>o_array(1,1003,2),mdsys.sdo_ordinate_array(4505553.2585,5430757
>>>>>>>.2937,4505551.1659,5430755.2011,4505553.2585,5430753.1085,45055
>>>>>>>55.3511,5430755.2011,4505553.2585,5430757.2937)));
>>>>>>>> Oracle Documentation:
>>>>>>>> Reading the Oracle Docs, I think all the objects are correct
>>>>>>>defined. The
>>>>>>>> geometries are validating by oracle 9i and oracle 10g (Using
>>>>>>>the st_valid -
>>>>>>>> method, e.g. SELECT a.GEOM.ST_IsValid()
>>>>>>>> FROM ax_bes_geblinie a WHERE a.fid = 14196363;).
>>>>>>>> Does anybody know a solution how to draw these objects with
>>>>>>>mapserver ?
>>>>>>>> greetings
>>>>>>>> Herbert
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: image/gif
Desc: ms-error.gif
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080923/7d9dd5a3/ms-error-0001.gif
Type: image/gif
Desc: ms-correct.gif
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080923/7d9dd5a3/ms-correct-0001.gif
