[mapserver-users] KML for WMS Service
Carlos Ruiz boolean10001 at yahoo.com
Tue Sep 23 10:25:36 EDT 2008
All,
PostgreSQL can output as KML using the AsKML function. Hope this helps you to, at
least, generate KML files.
IC Carlos Ruiz
--- On Tue, 9/23/08, Bob Basques <Bob.Basques at ci.stpaul.mn.us> wrote:
Subject: Re: [mapserver-users] KML for WMS Service
To: damarmo at gmail.com, mapserver-users at lists.osgeo.org
Date: Tuesday, September 23, 2008, 7:48 AM
All,
I don't think I'm answering your question directly, but I've
learned a few things about how Google earth imports WMS data directly, and that
in turn showed me how to export the layers from Google Earth into KML.  So now I
can write the appropriate KML output.
GE will import WMS services directly, but it's user interface leave a bit
to be desired on the operational side.  I've been toying around with the
same ideas though, where MapServer provides the result as a KML for GE use.
So, my next step would be to make use of a MapServer template to generate the
KML code (using the WMS export from GE as a starting point).  But this is where
I stopped in the steps, got other more pressing stuff at the moment.
bobb
>>> "David Martinez Morata" <damarmo at gmail.com>
09/23/08 4:00 AM >>>
Hi list.
I just a little question.
How I can create a KML file to show my WMS server in Google Earth?
Thanks
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080923/fd2d9329/attachment.html
