[mapserver-users] java mapscript + postgis = jvm crashed
Ludovico Bianchini metlud at yahoo.it
Tue Sep 23 16:50:05 EDT 2008
Umberto Nicoletti ha scritto:
> I am using postgis layers (on Linux, though) and it works fine.
> Do you share the same mapObj between threads (in application scope) or
> multiple requests (in session scope)?
> mapscript is safe only when a new mapObj is created for each request.
> What other kind of layers do you have in your map?
> Umberto
> On Mon, Sep 22, 2008 at 10:34 PM, Ludovico Bianchini <metlud at yahoo.it> wrote:
>> - Windows Vista Home Premium
>> - Postgres 8.1
>> - jvm 1.6.0
>> - jboss 4.0.3SP1, tomcat 5.5
>> - struts2
>> - ms4w 2.2.3 (mapscript.jar, mapscript.dll, all other dlls taken from this pack)
>> - postgresql-8.2-505.jdbc4.jar
>> mapscript.jar is placed in C:\jboss-4.0.3SP1\server\default\deploy\jbossweb-tomcat55.sar
>> When a layer with a postgis connection is turned on, the draw method crashes the jvm.
>> Error file attached.
>> Is there any solution to this problem?
>> Postgis is listed in "unsafe components", i have not understood if there is one way to make it work using thread syncronization.
>> Thanks in advance for any help.
>> Ludovico
>> __________________________________________________
>> Do You Yahoo!?
>> Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da tanto spazio gratuito per i tuoi file e i messaggi
>> http://mail.yahoo.it
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
I think I do not share the same object between request.
The other layer are shape file layer, they work fine (zoom ok, pan ok).
<struts><!-- Configuration for the default package. -->
    <package name="default" extends="struts-default">
        <action name="Mappa*" class="segnaletica.action.MappaAction"
method="{1}">
            <result>/jsp/mappa.jsp</result>
        </action>
    </package>
</struts>
public class MappaAction extends ActionSupport implements
ServletRequestAware{
    .//attributes
public String execute() throws Exception {
        mapObj mapObj_o = new
mapObj("C:\\jboss-4.0.3sp1_map\\map\\treviso.map");//create a new mapObj
object
        if(OP == null) OP = "-1";
        int op = Integer.parseInt(OP);
        switch (op) {
        case Z_IN: zoomIn(mapObj_o);
            break;
        case Z_OUT: zoomOut(mapObj_o);
            break;
        case PAN: pan(mapObj_o);
            break;
        case REFRESH: refresh(mapObj_o);
            break;
        default: fullExtent(mapObj_o);
            break;
        return SUCCESS;
    .//utility methods, map navigation methods
private void draw(mapObj mapObj_o){
        mapImageObj = mapObj_o.draw();//this instruction crashes the JVM
####                            LAYER SEGNALETICA
    LAYER
        NAME "segnaletica"
        STATUS OFF
        TYPE POINT
        TRANSFORM false
        POSTLABELCACHE true
        CONNECTION "user=user password=password dbname=dbname
host=localhost port=5432"
        CONNECTIONTYPE postgis
        DATA "posizionegeoref from rilievi.impianti"
        CLASS
            STYLE
                COLOR 255 99 0
                SYMBOL "circle"
                SIZE 12
            END
        END
        PROJECTION
            "init=epsg:4326"
        END
    END
Ludovico
Chiacchiera con i tuoi amici in tempo reale!
 http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
