[mapserver-users] java mapscript + postgis = jvm crashed
Umberto Nicoletti
umberto.nicoletti at gmail.com
Wed Sep 24 02:56:03 EDT 2008
On Tue, Sep 23, 2008 at 10:50 PM, Ludovico Bianchini <metlud at yahoo.it> wrote:
> Umberto Nicoletti ha scritto:
>> I am using postgis layers (on Linux, though) and it works fine.
>> Do you share the same mapObj between threads (in application scope) or
>> multiple requests (in session scope)?
>> mapscript is safe only when a new mapObj is created for each request.
>> What other kind of layers do you have in your map?
>> Umberto
>> On Mon, Sep 22, 2008 at 10:34 PM, Ludovico Bianchini <metlud at yahoo.it>
>> wrote:
>>> - Windows Vista Home Premium
>>> - Postgres 8.1
>>> - jvm 1.6.0
>>> - jboss 4.0.3SP1, tomcat 5.5
>>> - struts2
>>> - ms4w 2.2.3 (mapscript.jar, mapscript.dll, all other dlls taken from
>>> this pack)
>>> - postgresql-8.2-505.jdbc4.jar
>>> mapscript.jar is placed in
>>> C:\jboss-4.0.3SP1\server\default\deploy\jbossweb-tomcat55.sar
>>> When a layer with a postgis connection is turned on, the draw method
>>> crashes the jvm.
>>> Error file attached.
>>> Is there any solution to this problem?
>>> Postgis is listed in "unsafe components", i have not understood if there
>>> is one way to make it work using thread syncronization.
>>> Thanks in advance for any help.
>>> Ludovico
>>> __________________________________________________
>>> Do You Yahoo!?
>>> Poco spazio e tanto spam? Yahoo! Mail ti protegge dallo spam e ti da
>>> tanto spazio gratuito per i tuoi file e i messaggi
>>> http://mail.yahoo.it
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> I think I do not share the same object between request.
> The other layer are shape file layer, they work fine (zoom ok, pan ok).
> <struts><!-- Configuration for the default package. -->
> <package name="default" extends="struts-default">
> <action name="Mappa*" class="segnaletica.action.MappaAction"
> method="{1}">
> <result>/jsp/mappa.jsp</result>
> </action>
> </package>
> </struts>
> public class MappaAction extends ActionSupport implements
> ServletRequestAware{
Are you sharing any mapscript object as an Action attribute? If yes
that's probably the culprit, otherwis it seems pretty strange...
Does the crash occur only when more than user is accessing the map or
even when there is only one user?
Also ms4w 2.2.3 seems prett old, why don't you upgrade to the latest?
Umberto
> .//attributes
> public String execute() throws Exception {
> mapObj mapObj_o = new
> mapObj("C:\\jboss-4.0.3sp1_map\\map\\treviso.map");//create a new mapObj
> object
> if(OP == null) OP = "-1";
> int op = Integer.parseInt(OP);
> switch (op) {
> case Z_IN: zoomIn(mapObj_o);
> break;
> case Z_OUT: zoomOut(mapObj_o);
> break;
> case PAN: pan(mapObj_o);
> break;
> case REFRESH: refresh(mapObj_o);
> break;
> default: fullExtent(mapObj_o);
> break;
> return SUCCESS;
> .//utility methods, map navigation methods
> private void draw(mapObj mapObj_o){
> mapImageObj = mapObj_o.draw();//this instruction crashes the JVM
> #### LAYER SEGNALETICA
> LAYER
> NAME "segnaletica"
> STATUS OFF
> TYPE POINT
> TRANSFORM false
> POSTLABELCACHE true
> CONNECTION "user=user password=password dbname=dbname host=localhost
> port=5432"
> CONNECTIONTYPE postgis
> DATA "posizionegeoref from rilievi.impianti" CLASS
> STYLE
> COLOR 255 99 0
> SYMBOL "circle"
> SIZE 12
> END
> END
> PROJECTION
> "init=epsg:4326"
> END
> END
> Ludovico
> Chiacchiera con i tuoi amici in tempo reale!
> http://it.yahoo.com/mail_it/foot/*http://it.messenger.yahoo.com
