[mapserver-users] Metadata Hashtable
jeff at planyukon.ca
Wed Sep 24 10:43:40 EDT 2008
Steve,
Ticket #2773
Methods to expose the metadata hashtable in
mapscript/swiginc/hashtable.i need to be ported to php-mapscript to
provide for a $hash = $layer->{metadata} hashtableObj.
Thanks for your advice.
Jeff
Quoting Stephen Woodbridge <woodbri at swoodbridge.com>:
> Jeff,
> Did you write a bug for this? What bug number?
> Thanks,
> -Steve W
> Jeff Hamm wrote:
>> Thanks Steve.
>> Its finding the $hash I haven't got a handle on.
>> $oLayer->getMetaData("") wants a parameter key.
>> $oLayer->{metadata} returns nothing.
>> How do I grab the metadata hashtable itself?
>> Ticket #439 was the only reference I found; but the examples there
>> are same as above, unsuccessful.
>> Jeff
>> Steve Lime wrote:
>>> It should look something like this I believe (not a PHP guy):
>>> $key; # should be empty/NULL to start
>>> while($key = $hash->nextKey($key) {
>>> # do something with $key
>>> Steve
>>>>>> On 9/19/2008 at 3:38 PM, in message
>>>>>> <48D40DB2.3080103 at planyukon.ca>, Jeff Hamm
>>> <jeff at planyukon.ca> wrote:
>>>> Mapserver Bugzilla seems to indicate that exposing metadata as a
>>>> proper object is possible (Tickets #734 and #737).
>>>> I also want to print out all of the metadata key->value pairs for
>>>> a map layer using php-mapscript without explicitly naming them
>>>> all.
>>>> Can anyone share a code snippet for this?
>>>> TIA
>>>> Jeff Hamm
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
