[mapserver-users] transparent pixmaps in python mapscripts
Fawcett, David David.Fawcett at state.mn.us
Wed Sep 24 14:59:00 EDT 2008
Thanks Daniel,
I am not calling layer.draw(), just map.draw().
David.
-----Original Message-----
From: Daniel Morissette [mailto:dmorissette at mapgears.com]
Sent: Wednesday, September 24, 2008 8:45 AM
To: Fawcett, David
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] transparent pixmaps in python mapscripts
David,
TRANSPARENCY ALPHA works only between layers drawn using map.draw() in a
single pass. If you call layer.draw() for each layer in a loop in your
script then TRANSPARENCY ALPHA has no effect and that could explain the
problem you are encountering.
Daniel
Fawcett, David wrote:
> I am using a pixmap symbol to mark a point using Python MapScript v.
> 5.2.
> The image has a transparent background.  When I use the symbol with
> MapServer CGI, I the transparency works.  When I use the symbol in
> MapScript, I get a black background for the symbol, no transparency.
> Here is how I am creating the symbol:
> img = mapscript.imageObj(/symbols/redcross.png', 'GD/PNG')
> # create the symbol using the image
> symbol = mapscript.symbolObj('from_img')
> symbol.type = mapscript.MS_SYMBOL_PIXMAP
> symbol.setImage(img)
> symbol_index = mymap.symbolset.appendSymbol(symbol)
> I also tried to add this to the layer, but it made no difference
> either: inline_layer.transparency = mapscript.MS_GD_ALPHA
> Here is a gdalinfo report on the symbol image:
> Driver: PNG/Portable Network Graphics
> Files: redcross.png
> Size is 32, 32
> Coordinate System is `'
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,   32.0)
> Upper Right (   32.0,    0.0)
> Lower Right (   32.0,   32.0)
> Center      (   16.0,   16.0)
> Band 1 Block=32x1 Type=Byte, ColorInterp=Red
>   Mask Flags: PER_DATASET ALPHA
> Band 2 Block=32x1 Type=Byte, ColorInterp=Green
> Band 3 Block=32x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=32x1 Type=Byte, ColorInterp=Alpha
> Any ideas on how to get a pixmap symbol with a transparent background
> using python mapscript?
> Thanks,
> David.
Daniel Morissette
http://www.mapgears.com/
