[mapserver-users] Re: Transparency via WMS request?
Roger André
randre at gmail.com
Wed Sep 24 18:56:07 EDT 2008
Sorry, but I can't test that. I don't have pdf support compiled into this
version of Mapserver.
I did get transparency to work using the AGG driver by altering my
OUTPUTFORMAT to look like this:
OUTPUTFORMAT
NAME 'AGGA'
DRIVER AGG/PNG
IMAGEMODE RGBA
EXTENSION "png"
FORMATOPTION "TRANSPARENT=ON"
FORMATOPTION "INTERLACE=OFF"
TRANSPARENT ON
END #end outputformat
Unfortunately, it seemed to have decreased the quality of the rendering.
I've switched back to using the GD driver, and that seems to give good
quality and correct transparency.
OUTPUTFORMAT
NAME 'png'
DRIVER GD/PNG
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT ON
On Wed, Sep 24, 2008 at 3:39 PM, Robert Sanson <SansonR at asurequality.com>wrote:
> Is it possible to get layer transparency when outputformat=PDF?
> Thanks,
> Robert Sanson
> >>> "Roger André" <randre at gmail.com> 25/09/2008 10:36 a.m. >>>
> Thanks to some help from a fellow GIS developer, I think I've narrowed the
> problem down to the OUTPUTFORMAT section of my mapfile. Changing from the
> AGG to GD driver seemed to take care of the problem. Will need to do some
> additional futzing to see if I can get it working with AGG.
> On Wed, Sep 24, 2008 at 1:38 PM, Roger André <randre at gmail.com> wrote:
>> Ok, this is driving me bonkers. I have a raster image with nodata values
>> set to be transparent. When I make requests to this layer in "mode=map", it
>> works beautifully, and the nodata values are transparent.
>> http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/temp/temp.map&mode=map
>> However, when I try to view the same data via a WMS request, the nodata
>> values are displayed in black.
>> - http://localhost/cgi-bin/mapserv?map=/var/www/mapfiles/temp/temp.map
>> &SERVICE=WMS
>> &version="1.1.122
>> &REQUEST=GetMap
>> &LAYERS=imagery
>> &STYLES=
>> &BBOX=-180,-90,180,90
>> &WIDTH=600
>> &HEIGHT=500
>> &FORMAT=png
>> &SRS=epsg:4326
>> I have tried doing a couple of things to fix this, none of which has
>> worked:
>> - added "wms_transparent" "TRUE" to METADATA section of LAYER
>> - added "&TRANSPARENT=TRUE" to the end of the WMS request
>> - made sure that in OUTPUTFORMAT I have all of these:
>> OUTPUTFORMAT
>> NAME png
>> DRIVER "AGG/PNG"
>> MIMETYPE "image/png"
>> IMAGEMODE RGBA
>> EXTENSION "png"
>> TRANSPARENT ON
>> Please, can anyone tell me what I'm missing?
>> Thanks,
>> Roger
> Click here <https://www.mailcontrol.com/sr/wQw0zmjPoHdJTZGyOCrrhg==> to
> report this email as spam.
> The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080924/13fb24ae/attachment.html
