[mapserver-users] KML for WMS Service
Felipe Costa
fsc7mail at gmail.com
Thu Sep 25 10:21:23 EDT 2008
Hello,
I'm not sure what you want but I think you could take a look at
http://www.itopen.it/soluzioni/kml-map-server/
Best regards,
Felipe Costa
On Thu, Sep 25, 2008 at 8:47 AM, David Martinez Morata <damarmo at gmail.com>wrote:
> Thanks for all your answeres!
> I go to start testing with this information!
> Thanks
> 2008/9/23 Carlos Ruiz <boolean10001 at yahoo.com>
>> All,
>> PostgreSQL can output as KML using the AsKML function. Hope this helps you
>> to, at
>> least, generate KML files.
>> *IC Carlos Ruiz*
>> --- On *Tue, 9/23/08, Bob Basques <Bob.Basques at ci.stpaul.mn.us>* wrote:
>> From: Bob Basques <Bob.Basques at ci.stpaul.mn.us>
>> Subject: Re: [mapserver-users] KML for WMS Service
>> To: damarmo at gmail.com, mapserver-users at lists.osgeo.org
>> Date: Tuesday, September 23, 2008, 7:48 AM
>> All,
>> I don't think I'm answering your question directly, but I've
>> learned a few things about how Google earth imports WMS data directly, and that
>> in turn showed me how to
>> export the layers from Google Earth into KML. So now I
>> can write the appropriate KML output.
>> GE will import WMS services directly, but it's user interface leave a bit
>> to be desired on the operational side. I've been toying around with the
>> same ideas though, where MapServer provides the result as a KML for GE use.
>> So, my next step would be to make use of a MapServer template to generate the
>> KML code (using the WMS export from GE as a starting point). But this is where
>> I stopped in the steps, got other more pressing stuff at the moment.
>> bobb
>> >>> "David Martinez Morata" <damarmo at gmail.com>
>> 09/23/08 4:00 AM >>>
>> Hi list.
>> I just a little question.
>> How I can create a KML file to show my WMS server in Google Earth?
>> Thanks
>> mapserver-users mailing
>> list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Bendirei o senhor em todo o tempo,
Na minha boca sempre o seu louvor
Sl 34 (33),1–16
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080925/83aee28b/attachment-0001.html
