[mapserver-users] Including a variable title on a map?
thomas bonfort thomas.bonfort at gmail.com
Mon Sep 29 12:46:00 EDT 2008
try with
&map.layer[fid].feature[0]=TEXT+AS00001
thomas
On Sun, Sep 28, 2008 at 23:08, Robert Sanson <SansonR at asurequality.com> wrote:
> OK - thanks for the hints. I can now get a static string on my map as
> annotation, but I am still struggling to modify this via the URL. My map
> file snippet is:
>  LAYER
>   NAME fid
>   STATUS ON
>   TYPE annotation
>   TRANSFORM false
>   FEATURE
>     POINTS
>       600 20 #this is the position of the text in image coordinates (pixels)
>     END
>     TEXT "úrmid%"
>   END
>   CLASS
>     LABEL #defines the font, colors etc. of the text
>       FONT "arial"
>       TYPE TRUETYPE
>       SIZE 14
>       BUFFER 1
>       COLOR 255 0 0
>       OUTLINECOLOR 255 255 255 #--Halo
>       FORCE TRUE
>     END
>   END
>  END
> My URL contains this section:
> &map.layer[fid].feature[0].TEXT=AS00001
> I have tried with and without quotes around the TEXT, and also with and
> without feature[0].
> Any assistance appreciated.
> Robert Sanson
>>>> "Fawcett, David" <David.Fawcett at state.mn.us> 26/09/2008 1:35 a.m. >>>
> If you want to allow the title string to be passed through the URL, you can
> use URL Configuration changes to pass the text in.
> Take a look at this document (if you are using MapServer 5.x):
> http://trac.osgeo.org/mapserver/browser/branches/branch-5-0/mapserver/MIGRATION_GUIDE.TXT
> Scroll down to the section on URL configuration changes.  Take a look at
> example 3.  I am not sure if you can pass in just the text, or if you will
> need to pass in the feature coords and the text.
> Combine this with the example that Jukka pointed you to and you should be
> set.
> David.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen Jukka
> Sent: Thursday, September 25, 2008 1:36 AM
> To: Robert Sanson; mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Including a title on a map?
> Perhaps you could see if this copyright layer document points to right
> direction?
> http://mapserver.gis.umn.edu/docs/faq/copyright-layer
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Robert Sanson
> Lähetetty: 25. syyskuuta 2008 7:02
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Including a title on a map?
> Is it possible to print a title on a map? I would like to be able to send a
> variable on the URL containing a string to be used as a title to embed into
> the returned image in a particular location.
> I am using Javascript to formulate a CGI request for a PDF output, using
> mode=map.
> Many thanks,
> Robert Sanson
> The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
> This message has been scanned for malware by SurfControl plc.
> www.surfcontrol.com
> Click here to report this email as spam.
