[mapserver-users] ArcSDE 9.3 Support.
Nelson Soto NSoto at plotplans.com
Tue Sep 30 15:56:28 EDT 2008
After tracing dependencies with Dependency Walker, I can see sde.dll and
libmap.dll aren't loading correctly when loading 'msplugin_sde_92.dll'.
Any ideas on how to alleviate this?
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nelson
Soto
Sent: Tuesday, September 30, 2008 3:45 PM
To: Huey Brantley; Steve Lime
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] ArcSDE 9.3 Support.
Unfortunately, I'm trying to get the msplugin_sde_92.dll to even load as
a plug in at all. I get the following error :
msDrawMap(): Image handling error. Failed to draw layer named
'parcels-sde'. loadCustomLayerDLL: General error message. Failed to load
dynamic Layer LIB: D:\ms4w\Apache\specialplugins\msplugin_sde_92.dll
msGetSymbol(): General error message. Can't load requested dynamic
library: D:\ms4w\Apache\specialplugins\msplugin_sde_92.dll
The path is correct but is likely one of that dll's dependencies...
Ogrinfo and gdalinfo took some time to report 'SDE' in the formats list
and it was due to not being able to find the ArcGIS SDK dlls... I
couldn't figure out why (I did run SETENV.bat) so I just copied them
into the gdal-ogr folder and didn't overwrite any of the files that
perhaps may be shared but I'm sure this will lead to issues...
What steps did you follow to get this set up correctly? I have used ms4w
instructions for enabling and this doesn't seem to be effective... I
have the ArcSDE 9.3 C API SDK installed.
From: Huey Brantley [mailto:huey.brantley at vanderbilt.edu]
Sent: Tuesday, September 30, 2008 3:29 PM
To: Steve Lime
Cc: mapserver-users at lists.osgeo.org; Nelson Soto
Subject: Re: [mapserver-users] ArcSDE 9.3 Support.
I use MapServer with ArcGIS 9.3 with no problems.
On Tue, 2008-09-30 at 13:34 -0500, Steve Lime wrote:
> My assumption is that if it is not specifically stated that something
WON'T work with a particular
> version then it probably will work. I'd say try it. I don't have that
version handy or I'd do it myself.
> Steve
> >>> On 9/30/2008 at 12:06 PM, in message
<7BA6F57E003ADF4EA12DAA3043BB13D43B0D0D at geoexchange.DesLauriers.local>,
"Nelson
> Soto" <NSoto at plotplans.com> wrote:
> > I have seen this question asked but have not found any answers; Is
> > Mapserver capable of displaying and working with SDE 9.3??? The last
> > noted version I can see is 9.2 and am curious as it is not
explicitly
> > labeled as not working on the MapServer website.
> > Thanks,
> > Nelson
