[mapserver-users] Gdal seg fault with mapserver on Ubuntu
Ray Pendergraph
raymondpendergraph at yahoo.com
Wed Apr 8 08:59:17 EDT 2009
I am having a problem rendering labels to my map. I am running mapserver from ubuntu intrepid packages (none compiled). Kernel is 2.6.27-7-generic. Since this is obviously a common function I must be doing something wrong in the layer or something in the packages is not meshing. Everything works until I try to do anything with TrueType fonts, but I am not sure why gdal would have anything to do with this. When I try to add a label to a working layer (called 'clpoint'), the client gets a 500. Funny because the mapserver log reports lots of stuff like this for the layer (but no error):
40 2009].797599 msDrawMap(): Layer 6 (clpoint), 0.000s
[Wed Apr 8 08:24:40 2009].797672 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Apr 8 08:24:40 2009].797693 msDrawMap() total time: 0.001s
[Wed Apr 8 08:24:40 2009].803041 msFreeMap(): freeing map at 0x8d21ed8.
[Wed Apr 8 08:24:40 2009].895713 CGI Request 1 on process 29681
[Wed Apr 8 08:24:40 2009].896030 msWMSLoadGetMapParams(): enabling non-square pixels.[Wed Apr 8 08:24:40 2009].902272 msDrawMap(): kicking into non-square pixel preserving mode.[Wed Apr 8 08:24:40 2009].902928 msDrawMap(): Layer 6 (clpoint), 0.001s
[Wed Apr 8 08:24:40 2009].903194 msDrawMap(): Drawing Label Cache, 0.000s
[Wed Apr 8 08:24:40 2009].903236 msDrawMap() total time: 0.001s
[Wed Apr 8 08:24:40 2009].908839 msFreeMap(): freeing map at 0x8971ed8.
[Wed Apr 8 08:24:40 2009].928955 CGI Request 1 on process 29683
but syslog reports a bunch of these:
Apr 8 08:24:40 geoserver kernel: [1017419.869331] mapserv[29680]: segfault at bf41cfec ip b780fd4b sp bf41cfe0 error 6 in libgdal1.5.0.so.1.12.2[b7736000+4df000]
Apr 8 08:24:40 geoserver kernel: [1017419.916239] mapserv[29682]: segfault at bf72fffc ip b7821d56 sp bf730000 error 6 in libgdal1.5.0.so.1.12.2[b7748000+4df000]
--The layer in question:
LAYER
METADATA
wms_title "clpoint"
END
TYPE POINT
STATUS ON
NAME "clpoint"
DATA "../shapes/clpoint/clpoint.shp"
LABELITEM "CLPTLABEL"
LABELCACHE ON
CLASS
STYLE
COLOR 213 200 230
END
LABEL
TYPE TRUETYPE
FONT "arial"
SIZE 8
ANGLE FOLLOW
COLOR 25 25 175
OUTLINECOLOR 255 255 255
MINDISTANCE 200
PARTIALS FALSE
END
END
#This works fine
# CLASS
# STYLE
# SYMBOL "../symbols/historical.png"
# SIZE 20
# END
# END
JOIN
TABLE "../shapes/clpoint/clpoint.dbf"
NAME "clpoint"
FROM "PolyId"
TO "PolyId"
TYPE ONE-TO-ONE
END
END
--Mapserver configuration:
MapServer version 5.0.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
--gdlib configuration:
# gdlib-config --version
2.0.36
# gdlib-config --libs
-lXpm -lX11 -ljpeg -lfontconfig -lfreetype -lpng12 -lz -lm
--Gdal configuration:
# gdal-config --libs
-L/usr/lib -lgdal1.5.0 (this 1.5.0 seems odd to me)
#gdal-config --version
1.5.2
# gdal-config --ogr-enabled
yes
--The libraries:
-rw-r--r-- 1 root root 8817022 2008-07-04 11:08 /usr/lib/libgdal1.5.0.a
-rw-r--r-- 1 root root 1345 2008-07-04 11:08 /usr/lib/libgdal1.5.0.la
lrwxrwxrwx 1 root root 22 2009-04-07 16:29 /usr/lib/libgdal1.5.0.so -> libgdal1.5.0.so.1.12.2
lrwxrwxrwx 1 root root 22 2009-03-31 12:43 /usr/lib/libgdal1.5.0.so.1 -> libgdal1.5.0.so.1.12.2
-rw-r--r-- 1 root root 5438428 2008-07-04 11:08 /usr/lib/libgdal1.5.0.so.1.12.2
--Things I have checked
*The font.list is present and seems to be read (fails with a clearer error when I reference a fake font.).
*The font file is a valid true type font and has all permissions. Tried different fonts.
*The shape file and the dbf file are readable by other tools and CLPTLABEL in the dbf file has the data I want.
Can someone please tell me where I am going wrong (and thank you)? Sorry for the long post.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090408/4b47604c/attachment.html
