[mapserver-users] PHP MapScript inserting extra parameters into.map file
Steve Lime Steve.Lime at dnr.state.mn.us
Wed Apr 8 18:42:27 EDT 2009
All that's happening is MapServer is writing the default values for some of the parameters. The mapfile
before and after should be functionally equivalent. Not sure how that would wreak havoc. Your input
mapfile is using older syntax (no styles) that the mapfile writer can't/won't produce. So at a minimum
you'd see the style block as output.
>>> On 4/8/2009 at 4:56 PM, in message
<5b61c6c50904081456m4bd81c4dwde2011300bee2517 at mail.gmail.com>, Ian
<iansgis at gmail.com> wrote:
> Alright I've filed an enhancement ticket
> (http://trac.osgeo.org/mapserver/ticket/2975).
> I still don't understand why it happens though. Is MapScript defining
> parameters it feels should be there by default? This extra data is
> wreaking havoc on some other code and I need to stop it from reaching
> the .map file. Is defining these parameters in my .map file a solution
> to prevent these extra values from being appended?
> Thanks,
> Ian
> mapserver-users at lists.osgeo.org
