[mapserver-users] PHP MapScript inserting extra parameters
into.map file
Ian
iansgis at gmail.com
Thu Apr 9 15:02:22 EDT 2009
The display of the data still works, however the altered .map file is
no longer compatible with the OpenLayers wiki print.php code
(http://trac.openlayers.org/wiki/Printing). I can't figure out why. My
TileCache layers will still print but any layers coming from the PHP
MapScript-edited map file no longer work. print.php doesn't throw any
errors, the requested tiles all look valid, but the return is "500
Unexpected Error" and "Some unexpected error occurred. Error text was:
" with no error text. The relevant bits from my map file:
MAP
EXTENT -180 -90 180 90
FONTSET "/var/www/html/maps/fontset.txt"
IMAGECOLOR 60 100 145
IMAGETYPE png
SYMBOLSET "/var/www/html/maps/symbols.sym"
SHAPEPATH "data"
SIZE 500 500
STATUS ON
UNITS DD
NAME "My map"
OUTPUTFORMAT
NAME PNG24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
PROJECTION
"init=epsg:4326"
END
MAP
More is being changed by PHP MapScript than I realized, my
OUTPUTFORMAT block becomes:
OUTPUTFORMAT
NAME "png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
The layer that I am dynamically changing starts as:
LAYER
NAME "arrow"
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "arrow"
END
DATA shapefiles/arrow
STATUS ON
TRANSPARENCY ALPHA
CLASS
STYLE
ANTIALIAS TRUE
COLOR 255 0 0
OUTLINECOLOR 0 0 0
END ## Style
END ## Class
END ## Layer
and after PHP MapScript runs looks like:
LAYER
DATA "shapefiles/arrow"
METADATA
"wms_title" "arrow"
END
NAME "arrow"
PROJECTION
"init=epsg:4326"
END
STATUS ON
OPACITY ALPHA
TYPE POLYGON
UNITS METERS
CLASS
STYLE
ANGLE 360
ANTIALIAS TRUE
COLOR 255 0 0
OPACITY 100
OUTLINECOLOR 0 0 0
SYMBOL 0
END
END
END
PHP MapScript is changing the OUTPUTFORMAT configuration (including
deleting the FORMATOPTION "INTERLACE=OFF" parameter I need for
TileCache), adding UNITS METERS, STYLE ANGLE 360 OPACITY 100 END to
each LAYER, as well as changing TRANSPARENCY ALPHA to OPACITY ALPHA
for each LAYER in the map. I realize that the anti-aliasing syntax I
am using is deprecated and may change that but I'm going to ask again
for what I put in my enhancement request ticket yesterday:
Through a flag, configuration, directive, etc for PHP MapScript,
enable it to ONLY change the parameters supplied in the script, and
not alter/add/remove additional map parameters.
Thank you,
Ian
On Wed, Apr 8, 2009 at 3:42 PM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
> All that's happening is MapServer is writing the default values for some of the parameters. The mapfile
> before and after should be functionally equivalent. Not sure how that would wreak havoc. Your input
> mapfile is using older syntax (no styles) that the mapfile writer can't/won't produce. So at a minimum
> you'd see the style block as output.
> Steve
