[mapserver-users] MapServer 4 vs 5 seg fault
Liz Godwin
godwin.liz at gmail.com
Tue Apr 21 14:32:18 EDT 2009
ok. different problem then. I see nothing wrong with the expression
offhand. Perhaps the data type support has changed between versions?
On Tue, Apr 21, 2009 at 11:36 AM, Michael E Masscotte <masscotm at erau.edu>wrote:
> I haven't tried RHEL5 yet, but it happens with RHEL 4 and Solaris 10.
> Liz Godwin wrote:
> I've noticed a similar problem with EXPRESSION statements, but
>> inconsistantly. Are you running MS on Red Hat 5 by any chance?
>> On Tue, Apr 21, 2009 at 11:05 AM, Michael E Masscotte <masscotm at erau.edu<mailto:
>> masscotm at erau.edu>> wrote:
>> I've done some more investigation and found the seg fault happens
>> with a call to msDrawRasterLayerGDAL() according to gdb. I also
>> found what is tripping the core dump in the map file. I have an
>> class with 'EXPRESSION ([pixel] > 0)' so mapserver does not draw
>> black pixels. When I remove this, it works fine although it has
>> the black pixels I don't want. So, it appears I'm doing something
>> wrong with the EXPRESSION statement. Any one have any ideas how to
>> fix this or workaround it? Again, what I find strange is that this
>> works fine in MapServer 4.x but not 5.x.
>> Thanks for your help,
>> -Mike
>> Michael E Masscotte wrote:
>> I have a php script that generates a png from geotiff tiles.
>> The tiles are indexed using gdaltindex. The php script works
>> fine for MapServer 4.10.x but seg faults for version 5.x.x.
>> Does anyone know of any differences between version 4 and 5
>> that would cause this? Could it be from an older version of
>> gdal that the tiles are being generated with? This happens in
>> both RedHat Linux 4 as well as on our Solaris machines. I can
>> provide more details if someone can point me in the right
>> direction on where to look first for a problem.
>> Thanks is advance for any insight any one might provide!
>> -Mike
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090421/95f4fb0c/attachment.html
