[mapserver-users] GetFeatureINFO errors in Mapserver notoccurringin Geoserver.
Steve Lime Steve.Lime at dnr.state.mn.us
Fri Apr 24 09:01:13 EDT 2009
Could be a config error in the mapfile. What version of MapServer are you using? What does the
layer def look like?
Geoserver and MapServer are completely different code bases so they definitely approach SDE
differently.
Steve
>>> On 4/23/2009 at 6:45 PM, in message <1240530355847-2688375.post at n2.nabble.com>,
Michelle Douvil <mrdouville at shaw.ca> wrote:
> Hi Steve,
> Thanks for the suggestion..
> I attempted this URL
> http://server/mapserver/air-climate?&mapsize=1024+370&layers=AEI_AIR_QUALITY_AO
> I_O&mapxy=-126.94250575451+54.5026638549918&mode=query
> and it returned:
> Content-type: text/html msSDELayerGetShape(): SDE error.
> SE_stream_fetch_row(): Invalid parameter value passed to function. (-66)
> Looks like WMS and mapserver queries have problems at the same point in the
> code - msSDElayerGetShape()..
> I find it odd that Geoserver WMS seems to have no problem with the same sde
> layer data.
> Which makes me believe that the underlying SDE data may be OK, but Geoserver
> and Mapserver somehow do the queries to SDE differently..
> many thanks,
> Michelle
> Steve Lime wrote:
>> Sounds like more of an SDE problem than WMS. Can you query the SDE layer
>> outside of WMS just
>> using MapServer queries?
>> Steve
