[mapserver-users] Mapserver returns part of an image and then crashes
Tamas Szekeres szekerest at gmail.com
Fri Apr 24 13:20:44 EDT 2009
Which binaries are you using?
Could you provide the sample data with a mapfile to repoduce it?
Best regards,
Tamas
2009/4/24 Nelson Correia <nelsonwc7 at hotmail.com>
> Hi,
> I am using mapserver on windows, and recently, after a few changes in my
> configuration, it started crashing (only for some bounding boxes - some
> areas of the map are returned without problem), without returning an error
> message. It returns only part of the image, but then the mapserver process
> crashes with the following information:
> * Problem signature:
> * Problem Event Name: APPCRASH
> Application Name: mapserv.exe
> Application Version: 0.0.0.0
> Application Timestamp: 4935ad86
> Fault Module Name: ntdll.dll
> Fault Module Version: 6.0.6001.18000
> Fault Module Timestamp: 4791a783
> Exception Code: c0000005
> Exception Offset: 0002f8f4
> OS Version: 6.0.6001.2.1.0.272.7
> Locale ID: 2070
> Additional Information 1: c997
> Additional Information 2: ae645009e6c492243309385fb187f9cb
> Additional Information 3: 8219
> Additional Information 4: b67578da7791af77bcf37b260b2c58a9
> I reverted the changes I've made to a configuration that worked before, but
> I am no longer able to run it properly, it crashes all the time for certain
> zones of the map.
> Any ideas?
> Thanks,
> Nelson
> Get news, entertainment and everything you care about at Live.com. Check
> it out! <http://www.live.com/getstarted.aspx>
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090424/88bdc4b6/attachment.html
