[mapserver-users] Mapfile HDF 'DATA' element format
Peter Willis peterw at borstad.com
Wed Apr 29 11:20:34 EDT 2009
Frank Warmerdam wrote:
> One SDS with more than one band (ie. rank 3 with the third rank
> more than a dimension of 1) is accessed normally as long as you want
> to use the first three bands as RGB.  If you want to control which bands
> you use, add the BANDS PROCESSING option.
> eg.
> PROCESSING "BANDS=4,2,1"
> The tricky case is more than one SDS which is normally when you
> start seeing subdatasets.  Normally you would use gdalinfo to
> identify what subdatasets are available.
Hello Frank,
Thanks for clarifying. Maybe I should be filling out
the wiki somewhere regarding this information.
Peter
