[mapserver-users] Mapserver 5.4 & SYMBOLSET
Daniel Morissette
dmorissette at mapgears.com
Thu Apr 30 10:36:42 EDT 2009
Are you sure that the file you are editing is really the one used by
your mapfile? That's a common mistake... to verify that, try inserting
an invalid keyword in place of the SYMBOLSET keyword in your file and
verify that MapServer produces a parser error about it. If it doesn't
then it's probably not using the file you think it is.
Daniel
David Nugent wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> It starts (and ends) like this:
> SYMBOLSET
> SYMBOL
> NAME "point"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED TRUE
> END
> SYMBOL
> NAME "dashed"
> TYPE ELLIPSE
> POINTS
> 1 1
> END
> FILLED TRUE
> STYLE
> 8 6 8 6
> END
> END
> END
> Regards,
> David
> On 30/04/2009, at 1:13 PM, Steve Lime wrote:
>> Can you share your symbolset file? I've not had an issue with that
>> change.
>> Steve
>>>>> David Nugent <davidn at datalinktech.com.au> 04/29/09 9:54 PM >>>
>> Hello all,
>> I've recently upgraded to mapserver 5.4 and hit a problem with
>> SYMBOLSET.
>> It seems that a file containing symbols referenced from the .map file
>> must now contain a SYMBOLSET keyword at the start (and presumably end
>> with END?). I made this change, but the parser still complains with
>> the message "First token must be SYMBOLSET".
>> Not really wanting to waste time on debugging the lex code, I simply
>> removed the check that emits this error from mapsymbol.c and all works
>> as expected. Obviously there is a deeper problem, whether it be the
>> logic in that statement (which appears to be correct as far as I can
>> tell) or the lex parser itself.
>> I'm just wondering if anyone else had hit the same problem.
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.8 (Darwin)
> iEYEARECAAYFAkn5IX4ACgkQgyBtWyGDJqVRXACfZnjgfrOnb7nQmKTF99gjA4WX
> bMEAn28/+mRNOk60rbeTX4BbQUBF1q4L
> =vbTf
> -----END PGP SIGNATURE-----
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
