[mapserver-users] MapServer+OpenLayers+TileCache
bartvde at osgis.nl
bartvde at osgis.nl
Tue Aug 4 08:43:28 EDT 2009
Hi Jelmer,
PROJECTION of a LAYER is the projection of your source data, so I assume
that's RD in your case or not?
So use:
LAYER
PROJECTION
"init=epsg:28992"
END
METADATA
"wms_srs" "EPSG:28992 EPSG:4326"
END
END
Example tilecache config:
[satlufo]
type=WMSLayer
layers=basis,satlufo
debug=false
url=http://145.50.148.45:8081/rwsnl/tiled?_tilecache&transparent=false&
extension=png
srs=EPSG:28992
bbox=-400000,225000,625000,950000
resolutions=1400.00365346073000,700.00182673036700,280.00073069214700,140.00036534607300,70.00018267303670,28.00007306921470,14.00003653460730,7.00001826730367,2.80000730692147
metaTile=true
metaBuffer=100
extent_type=loose
Best regards,
Bart
> Hello List,
> I've been messing around with TileCache for a while now, trying to see
> if I can get it to work the way I want. It does work, but I'm unable to
> "switch" to the projection system that I need, which is epsg:28992
> (amersfoort new).
> Whatever I try, I always end up with the world showing up OK, but the
> Netherlands (which is what this is about) messed up and stretched. I
> feel like I tried everything: tell TileCache to use epsg:4326 or 28992,
> test in my Map file by changing the PROJECTION block (tried "auto",
> "init=epsg:28992", etc), change the wms_srs to 4326,28992 and more.
> This is my TileCache definition:
> [test]
> type=WMSLayer
> layers=netherlands,world
> url=[myurl]
> srs=EPSG:4326
> My mapfile is still messed up from pervious experiments, but it's now:
> MAP
> NAME test
> FONTSET "fontset.txt"
> IMAGECOLOR 255 255 255
> OUTPUTFORMAT
> NAME aggpng24
> DRIVER AGG/PNG
> TRANSPARENT ON
> IMAGEMODE RGBA
> MIMETYPE "image/png"
> EXTENSION "png"
> END
> WEB
> METADATA
> "wms_title" "CoconTheWeb - Eurofiber"
> "wms_srs" "EPSG:4326"
> "wms_onlineresource" "[myurl]"
> END # METADATA
> END #web
> SYMBOLSET "symbols_mapinfo.sym"
> PROJECTION
> "init=epsg:4326"
> END
> LAYER
> NAME netherlands
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "C:\Mapinfo\data\Streetpro\NETHA0.tab"
> #STYLEITEM "AUTO"
> CLASS
> COLOR 255 247 214
> END
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "netherlands"
> "wms_srs" "epsg:28992,4326"
> END # METADATA
> END
> LAYER
> NAME world
> TYPE LINE
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "C:\MapINfo\Data\StreetPro\wrlda0.tab"
> STYLEITEM "AUTO"
> CLASS
> name "world"
> end
> METADATA
> "wms_title" "world"
> END # METADATA
> MINSCALE 4
> MAXSCALE 4000000000
> END
> END # Map File
> I know there's much that needs to be changed/cleaned up in my Map File,
> I'll do that later. Anyone know what I'm doing wrong, here?
> Regards,
> Jelmer Baas
> mapserver-users at lists.osgeo.org
