[mapserver-users] MapServer and SLD/SE
Alexander Reichelt
alexander.reichelt at gmx.de
Tue Aug 11 18:45:59 EDT 2009
Hi there,
thank you for your fast answer.
Yes, the SE specification states that Rotation expects a number. The
angle attribute in my PostGIS has the type 'real' so its supposed to be
a number.
So I have the following questions:
- does the data type of the attribute cause the problem or
- does the expression <ogc:PropertyName>...</ogc:PropertyName> cause the
problem because MapServer doesn't support the access on a table
regarding Rotation and only works with a fix value in general?
Somewhere I have found a deprecated method for getting access on an
attribute (which didn't use PropertyName), I also tried this and it
didn't work. By the way, I'm using MapServer 5.4.
Before I condemn MapServer for not supporting the attribute binding for
Rotation: How could I check up if there's probably a type cast from a
'real' attribute of the PostGIS table to a 'string' attribute? Which
other data type could I try rather than 'real'?
Is there a way to track the exact request from MapServer to PostGIS and
back again?
Is there anyone who tried rotating via SLD/SE in combination with
attribute binding and not just via a fix value?
Bye
Alex
P.S. Thank you for opening the ticket on the TTF issue
Yewondwossen Assefa wrote:
> Alexander Reichelt wrote:
>> Hi list,
>> I've got some issues with the MapServer and SLD/SE 1.1.0:
>> 1. I can't rotate my labels. They are displaying the string value I'm
>> reading out of a PostGIS table correctly. But the real value standing
>> for an angle they doesn't seem to use. My TextSymbolizer looks like
>> this:
>> <se:TextSymbolizer>
>> <se:Label>content</se:Label>
>> <se:Font>
>> <se:SvgParameter name="font-family">arialbold</se:SvgParameter>
>> <se:SvgParameter name="font-size">10.00</se:SvgParameter>
>> </se:Font>
>> <se:LabelPlacement>
>> <se:PointPlacement>
>> <se:AnchorPoint>
>> <se:AnchorPointX>0.5</se:AnchorPointX>
>> <se:AnchorPointY>0.5</se:AnchorPointY>
>> </se:AnchorPoint>
>> <se:Rotation>
>> <ogc:PropertyName>angle</ogc:PropertyName>
>> </se:Rotation>
>> </se:PointPlacement>
>> </se:LabelPlacement>
>> <se:Fill>
>> <se:SvgParameter name="fill">#000000</se:SvgParameter>
>> </se:Fill>
>> </se:TextSymbolizer>
>> When I type in a fix value like 220.5 then it works and all labes are
>> displayed with this angle. The curious thing is, when I exchanged the
>> content item with the angle item then the angle item was displayed,
>> so the MapServer does have access to the angle item. Is it possible
>> that there's a typecast which casts the real value of the angle into
>> a string? How can I check this? I've tried to change the XML elements
>> but nothing helped me so far.
> Rotation is defined as a number in the SLD specs and that is what is
> currently expected when parsing the SLD in MapServer.
> Using attributes from your data for the rotation/angle parameter (or
> for that matter for all parameters that have attribute binding
> capabilities in Mapserver), could possibly be supported (at least in
> cases where the the value in the sld is a string and the expected
> value is numeric). You can possibly enter an enhancement bug on this
> and start a discussion in that bug.
>> 2. MapServer doesn't support TrueType symbols for PointSymbolizers,
>> is this correct? The website states that MapServer supports
>> Well-known names. I've tried to point on a .ttf file and use
>> MarkIndex to get out a symbol but I had no success.
> That is correct, only Well-known symbols as well as well as gif/png
> symbols are supported. I have entered a enhancement bug on it [1]
> [1]: http://trac.osgeo.org/mapserver/ticket/3084
> best regards
>> Thank you in advance
>> Alex
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
