[mapserver-users] Too Many Open Files
aseem aseembatish at gmail.com
Wed Aug 12 09:30:52 EDT 2009
Thanks Daniel. Thanks for the reply. Yes, We are using MapScript. I have
checked the open files by executing lsof command. I found that most of the
files are related to FGS. Following is the part of the output we got after
running lsof command.
httpd     23793    apache  DEL       REG                0,8
5304375 /dev/zero
httpd     23793    apache  mem       REG              147,1      67584
2949497 /data/fgs/www/logs/jk-runtime-status
httpd     23793    apache  mem       REG              147,1     478913
2949206 /data/fgs/www/modules/mod_jk.so
httpd     23793    apache  mem       REG              147,1     238336
2998379 /data/fgs/lib/libpng12.so.0.1.2.8
httpd     23793    apache  mem       REG              147,1    1116483
2998285 /data/fgs/lib/libiconv.so.2.2.0
httpd     23793    apache  mem       REG              147,1    2921477
2998415 /data/fgs/lib/libxml2.so.2.6.19
httpd     23793    apache  mem       REG              147,1     126672
2998332 /data/fgs/lib/libjpeg.so.62.0.0
2998279 /data/fgs/lib/libpng.so.3.1.2.8
httpd     23793    apache  mem       REG              147,1     449524
2998348 /data/fgs/lib/libfreetype.so.6.3.16
httpd     23793    apache  mem       REG              147,1     242996
2998297 /data/fgs/lib/libgd.so.2.0.0
httpd     23793    apache  mem       REG              147,1     909044
2998398 /data/fgs/lib/libstdc++.so.6.0.8
httpd     23793    apache  mem       REG              147,1    4560732
2949501 /data/fgs/www/libexec/libphp5.so
httpd     23793    apache  mem       REG               8,17      27836
2717861 /lib/libcrypt-2.5.so
httpd     23793    apache  mem       REG              147,1     146660
2949194 /data/fgs/www/lib/libapr-1.so.0.2.12
httpd     23793    apache  mem       REG              147,1     111948
2949172 /data/fgs/www/lib/libexpat.so.0.1.0
httpd     23793    apache  mem       REG              147,1      87908
2949197 /data/fgs/www/lib/libaprutil-1.so.0.2.12
httpd     23793    apache  mem       REG               8,17      46740
2717128 /lib/libnss_files-2.5.so
httpd     23793    apache  mem       REG              147,1      41096
2998325 /data/fgs/lib/libgcc_s.so.1
httpd     23793    apache  mem       REG              147,1      79184
2998333 /data/fgs/lib/libz.so.1.2.3
httpd     23793    apache    0r      CHR                1,3
1895 /dev/null
httpd     23793    apache    1w      CHR                1,3
1895 /dev/null
httpd     23793    apache    2w      REG              147,1      34909
2949498 /data/fgs/www/logs/error_log
httpd     23793    apache    3u     IPv6            5304241
TCP *:pichat (LISTEN)
httpd     23793    apache    4u     sock                0,5
5304242 can't identify protocol
httpd     23793    apache    5r     FIFO                0,6
5304372 pipe
httpd     23793    apache    6w     FIFO                0,6
5304372 pipe
httpd     23793    apache    7w      REG              147,1    2953030
2949499 /data/fgs/www/logs/access_log
httpd     23793    apache    8w      REG              147,1    1452012
2949495 /data/fgs/www/logs/mod_jk.log
httpd     23793    apache    9u      REG              147,1      67584
httpd     23793    apache   10u      REG              147,1          1
2949496 /data/fgs/www/logs/jk-runtime-status.lock
httpd     23793    apache   11r     0000               0,10          0
6750301 eventpoll
httpd     23793    apache   12u     sock                0,5
6750302 can't identify protocol
httpd     23793    apache   13u     IPv4            6750305
TCP localhost.localdomain:46025->localhost.localdomain:8009 (ESTABLISHED)
httpd     23794    apache  cwd       DIR               8,17       4096
2 /
httpd     23794    apache  rtd       DIR               8,17       4096
2 /
httpd     23794    apache  txt       REG              147,1     655824
2949473 /data/fgs/www/bin/httpd
httpd     23794    apache  mem       REG               8,17     125728
2718127 /lib/ld-2.5.so
httpd     23794    apache  mem       REG               8,17    1585788
2717105 /lib/libc-2.5.so
httpd     23794    apache  mem       REG               8,17     208344
2717112 /lib/libm-2.5.so
httpd     23794    apache  mem       REG               8,17      16528
2717120 /lib/libdl-2.5.so
httpd     23794    apache  mem       REG               8,17     125668
2717167 /lib/libpthread-2.5.so
httpd     23794    apache  mem       REG               8,17     101504
2717213 /lib/libnsl-2.5.so
httpd     23794    apache  mem       REG               8,17      76396
2717177 /lib/libresolv-2.5.so
httpd     23794    apache  mem       REG               8,17      44088
2717090 /lib/librt-2.5.so
httpd     23794    apache  mem       REG               8,17   56464208
5405420 /usr/lib/locale/locale-archive
httpd     23794    apache  DEL       REG                0,8
5304375 /dev/zero
httpd     23794    apache  mem       REG              147,1      67584
httpd     23794    apache  mem       REG              147,1     478913
httpd     23794    apache  mem       REG              147,1     238336
httpd     23794    apache  mem       REG              147,1    1116483
httpd     23794    apache  mem       REG              147,1    2921477
httpd     23794    apache  mem       REG              147,1     126672
httpd     23794    apache  mem       REG              147,1     449524
httpd     23794    apache  mem       REG              147,1     242996
httpd     23794    apache  mem       REG              147,1     909044
httpd     23794    apache  mem       REG              147,1    4560732
httpd     23794    apache  mem       REG               8,17      27836
httpd     23794    apache  mem       REG              147,1     146660
httpd     23794    apache  mem       REG              147,1     111948
httpd     23794    apache  mem       REG              147,1      87908
httpd     23794    apache  mem       REG               8,17      46740
httpd     23794    apache  mem       REG              147,1      41096
httpd     23794    apache  mem       REG              147,1      79184
httpd     23794    apache    0r      CHR                1,3
1895 /dev/null
httpd     23794    apache    1w      CHR                1,3
1895 /dev/null
httpd     23794    apache    2w      REG              147,1      34909
Daniel Morissette wrote:
> aseem wrote:
>>  Dear All,
>> We are using UMN Map server(FGS) with integration to apache tomcat server
>> through MOD.JK Connector. Whenever we are running our application our web
>> application hangs up. we found that there are so many open files of FGS
>> server on our linux server. It seems that our web application hangs up
>> due
>> to these open files. Our application works fine for only20-30 mins.
> Are you using the mapserv CGI or MapScript? Perhaps you could start by
> using "lsof" to figure which files are left open. That could give you an
> idea of the source of the problem.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
> mapserver-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Too-Many-Open-Files-tp3429559p3430711.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
