[mapserver-users] WMS-GetFeatureInfo and EMPTY-mapfile-tag
Stephan Holl
stephan.holl at intevation.de
Wed Aug 12 09:57:17 EDT 2009
Hello Daniel,
thanks for your reply.
Daniel Morissette <dmorissette at mapgears.com>, [20090812 - 09:02:21]
> Stephan Holl wrote:
> > Dear MapServers,
> > can somebody put some light in the behaviour of the
> > EMPTY-mapfile-tag in combination with WMS GetFeatureInfo-Requests?
> Which version of MapServer are you using? Support for the EMPTY
> keyword in WMS GetFeatureInfo was added only in v5.2 (ticket #546).
We tried with version 4.6.1; does your above sentence means that it is
only added in v5.2 or >=5.2?
> > Currently I cannot make it work with a valid HTML-template provided
> > within the EMPTY-mapfile-tag and a request with
> > info_format=text/html.
> What do you get? An error message? A blank page?
Currently we get a blank page back.
> Something else?
> What do you put in the EMPTY parameter? It should be a URL for a
> redirect and not an actual template, see
> http://mapserver.org/mapfile/web.html
Yes, I have read that already. So the behaviour between the
EMPTY-keyword changed somewhere, because I was of the opinion that
there could have been set a file as well in earlier version of
mapserver 4.10.x (at least for CGI-mode).
Best
Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090812/b0a685d1/signature.bin
