[mapserver-users] WFS: msMSSQL2008LayerGetShapeRandom bad shape: 1
D Boyd
davidboyd at ntlworld.com
Wed Aug 12 11:07:27 EDT 2009
Hi folks,
I'm having a little trouble creating a WFS that takes data from a MS SQL
2008 database. I have a table that stores points of interest, the table has
a unique field (PointID) and a geometry field (PointPos) that stores the
location.
Previously I created a WMS that serves a map with these points drawn on
which worked fine, with the WFS however none of the points are being
returned in the feature collection. The following is displayed in the error
log:
Wed Aug 12 15:55:11 2009].450000 in msMSSQL2008LayerGetItems (find column
names)
[Wed Aug 12 15:55:11 2009].450000 msMSSQL2008LayerInitItemInfo called
[Wed Aug 12 15:55:11 2009].450000 msMSSQL2008LayerGetShape called for record
= 1
[Wed Aug 12 15:55:11 2009].450000 msMSSQL2008LayerGetShape: select
convert(varchar(max), PointID),convert(varchar(max),
PointIdentifier),convert(varchar(max), PointDate),convert(varchar(max),
PointClass),convert(varchar(max), PointSubClass),PointPos from Points where
PointID = 1
[Wed Aug 12 15:55:11 2009].450000 msMSSQL2008LayerGetShapeRandom bad shape:
1
[Wed Aug 12 15:55:11 2009].450000 mapserv request processing time (msLoadMap
not incl.): 0.372s
The getshape query in is returning the correct row with the PointPos in hex
(tested SQL managment studio).
The layer is as follows:
LAYER
NAME "PointData"
DEBUG 5
METADATA
wfs_title "Point data test"
gml_featureID "PointID"
wfs_version "1.0.0"
wfs_typename "PointData"
END
CONNECTIONTYPE PLUGIN
TYPE POINT
PLUGIN "C:/mapserver/msplugin_mssql2008.dll"
CONNECTION "sql connection string"
DATA "PointPos FROM Points"
STATUS ON
PROJECTION
"init=epsg:27700"
END
DUMP TRUE
CLASS
STYLE
COLOR 0 0 255
END
END
END
Any help with this issue would be greatly apreciated!
View this message in context: http://n2.nabble.com/WFS%3A-msMSSQL2008LayerGetShapeRandom-bad-shape%3A-1-tp3431353p3431353.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
