[mapserver-users] mapscript - Unable to load dynamic library
'/usr/lib/php/modules/php_mapscript.so' undefined symbol: gdImagePngCtx
ted_s
tspradley at snoogems.com
Wed Aug 12 12:17:59 EDT 2009
Following up - a general Unix reminder that was a minor stumbling block when
checking:
# mapserv -v
and finding that my configure settings were not present. Always do a 'make
clean', then 'make'!
Semi-resolved
So, Apache's error log now contains
PHP Warning: PHP Startup: Unable to load dynamic library
'/usr/lib/php/modules/php_mapscript.so' -
/usr/lib/php/modules/php_mapscript.so: undefined symbol: php_gd_gdImageCopy
However, running mapserv from the command line gives the proper response
# mapserv
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
and now running the script phpinfo_mapscript.phtml including the
dl("php_mapscript.so") runs properly and shows Mapserver/Mapscript as a
correctly configured PHP module ...
Sorry for the long post. I seemed to have answered my question in the
process of asking it, but am sure I will run into the php_gd_gdImageCopy as
a problem, but will cross that bridge when I come to it and refer back to
this post. Hope this helps someone. I have seen this same issue in the
archives for years with no definitive posts on the outcome.
View this message in context: http://n2.nabble.com/mapscript---Unable-to-load-dynamic-library-%27-usr-lib-php-modules-php_mapscript.so%27-undefined-symbol%3A-gdImagePngCtx-tp3431004p3431957.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
