[mapserver-users] How to Optimize Particular Raster Lookup
Pavel Iacovlev iacovlev.pavel at gmail.com
Wed Aug 12 12:12:35 EDT 2009
I would make something among this lines like cache all elevation for
each geometry.
1. Create a table elevation_points
id - (index)
table - table name (index) (if you have multiple data tables)
parent_id - id of the linestring (index)
the_geom - point - (index)
value - elevation value
2.
Make a PHP script that populates elevation_pointst table using the
algorithm you already developed, or create a ON UPDATE trigger for the
geometry, so then the geometry is changed the elevation_points are set
accordingly to changes.
3.
Using a SQL JOIN fetch the data in a preferred way very fast.
On Wed, Aug 12, 2009 at 5:40 PM, Blake Crosby<me at blakecrosby.com> wrote:
> Hello! Wondering if a few of you can provide some insight here:
> Problem: Given a linestring, return the elevation data along that
> linestring from CDED data (ASCII DEM).
> I'm using Mapserver 5.4.2
> I'm using PHP Mapscript and queryByPoint to get values from my DEMs.
> However, the performance seems really slow. Essentially here is how I
> have things set up:
> Fetch Linestring from postgis, and select N points from the string every
> Y distance (ie, get the points every 1 km).
> Loop through each point and do a queryByPoint() to get the value from
> Mapserver.
> I've tried using a tilecache, yo no avail. It still takes over 60
> seconds to query approx 200 points.
> I would like to use the 50k CDED dems, however the performance is even
> worse. So i'm using the 250k ones, approx 4,280 files.
> Any tips on improving performance?
> Blake
> mapserver-users at lists.osgeo.org
http://iap.md, The future is open
