[mapserver-users] Scaling Image Symbol Offset
David Martin David at itbeyond.com.au
Thu Aug 13 09:30:45 EDT 2009
I am developing a new application and am rendering around a load of
graphic symbol layers using a Map file layer such as
LAYER
    NAME        cape_headland_point
    STATUS      ON
    GROUP       all
    DATA        'ExplorOz/Places/Cape,Headland,Point'
    TYPE        POINT
    SYMBOLSCALE 1000000
    CLASS
        STYLE
            SYMBOL [POIImage]
            MAXSIZE 15
            MINSIZE 4
            SIZE 8
        END
    END
    METADATA
          "wms_title"         "Capes, Headlands & Points"
      END
    PROJECTION
        "+proj=longlat +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +no_defs"
    END
END
As you can see I am sizing the output symbol which is a 20x20px PIXMAP
image - this is working great however the position of the image needs to
be OFFSET up by half the size of the image (to make the actual point be
the center of the image) - I have tried using OFFSET however when the
image size changes (based on SYMBOLSCALE)the offsets are wrong. Is there
a way to OFFSET image symbols based on the SYMBOLSCALE and MAX/MIN
SIZES?
Regards
David
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090813/ab3d36b9/attachment.html
